Demko Knives MWallace
Moderator
- Oct 17, 2023
That’s what I was going to suggest, though not the idea you came up with using the threaded barrel. You need a shouldered pin, though I have no idea where to find one or what size you’d need. Or you could use digital calipers and see the diameter of the shouldered pin. Maybe an 1/8” or 5/32” straight pin would work? Those can be easily found and you could grind or cut to length. But you would also have to drill the scales to fit. The solution you found is a brilliant one! Of the two possible fixes both have their risk and I’m not sure of your comfort level in these. For #2, be careful as I don’t think the scales lay flat due to the contours of the handles. Good luck.Because I just can't leave well enough alone, I've come up with a brilliant work around. I need a new stop pin with a larger diameter in order to cure the blade rap. I don't even know where to begin looking for a replacement because I don't even know what terms to search for. But wouldn't ya know it, the threaded inserts (barrel nut?) for the ends of the clip screws just happen to be the same diameter as the stop pin.
And it fits like a glove, AND it perfectly cures my self imposed blade rap. Plus I figure (hope) I can get by with just 2 clip screws.
Perfect fix, right? Nope, the threaded barrel is longer than the stop pin and the recesses in the G10 for the stop pin are not deep enough, so the scales won't fit back into place.
So now I have another dilemma:
1. Do I file down the threaded barrel to fit the existing holes in the G10, thereby permanently sacrificing the threaded barrel? OR
2. Do I drill the stop pin holes a bit deeper and risk permanently removing the possibility that the original stop pin will fit again?
I'm leaning towards #2 as the stop pin is pretty well useless at this point. Does anyone have any thoughts from a different perspective?
