In truth, almost anything can be made to cut wood- it depends on the task and the style of cutting. Long before I developed a serious interest in knives , I did tons of woodworking and I'm very adept at using chisels. I've also cooked for a long time and know how to use knives in the kitchen for everything from butchering to delicate garnishing.
What I surmise is a scandi grind is essentially a chisel grind on a knife rather than on a dedicated chisel. This tells me a lot, as I would never want to try doing with a knife what I know a chisel does best. Scandi ground knives are best for carving in a chiseling manner- short precise chunks of green or seasoned wood. Flat grinds introduce that more friction through an increase in surface area between the blade's sides and the wood being SLICED. Flat grinds are slicing kings. Convex grinds can chop and they can carve poorly but they skin like a dream.
Interestingly, I find that the coatings on many modern day knives- the matte or crinkle coatings hugely impede work! So a Flat ground crinkle coated knife is about as much work as you could possible make for yourself in carving or chopping into wood. You can struggle and win over such a predicament but why bother?
Before we put down the scandi grinds, run out and buy some cheap chisels, something 1" wide should suffice. Now go at some wood and then try some of your flat ground knives.
The saber style grind with either a zero, small secondary, or small convexed edge, associated with the Scandinavian knives are not chisel grinds, nor do they resemble such in appearance, or in performance. Apples and oranges. If I misinterpreted something here, please correct this old engineer.
More important than the grind one takes to the bush, is the skill of its user. Too, if there is not a high level of sharpening proficiency with the grind one carries, the benefits of that grind just won't matter much.
Many are surprised, when woodworking, when I hand them a flat-grind with a polished convexed edge. The expression on their faces is like going from rags to riches. Some complain about the Scandinavian grind having a "wedging effect" when carving some types of wood. Note; if you correctly polish the primary grind (the primary grind needs to be absolutely flat to begin with -- shortcuts don't work), then polish the shoulders, the blade will sail through a nice carving project. Can't blame the chainsaw if the user can't properly maintain the chain.![]()
We can agree to disagree. Disliking your preference doesn't imply that someone doesn't know what they are doing either.
