Bushnell Match Pro Rifle Scope 6-24x50 30mm FFP Deploy Mil
BMCGear
Feedback: +378 / =0 / -0
e this scope's condition as excellent. It was purchased new by me and comes with the box. The scope was mounted to a CZ 457 with Burris Signature Zee Rings (look ma, no ring rash!). The only reason for moving it is that for the purpose of this rifle I'm not needing a FFP reticle anymore. Only had about 50 shots fired while mounted.
So, save yourself a little off of a new scope plus shipping and taxes (if your state charges tax).
Asking $300 shipped. Paypal F&F or USPS Money Order preferred.
Pictures up soon!
Description
Bushnell’s Match Pro 6-24x50mm Riflescope is an entry-level optic with professional-level features. Well suited for PRS, NRL, and NRL22 rifles, the Match Pro 6-24x50mm is equipped with easy base-10 turrets for fast rev counting and greater shooter confidence. These turrets allows the user to feel and hear every click, and can be reset in seconds without the use of tools. The 30mm main-tube allows for 18 MIL of elevation for accurate shots out to 1000 yards, and a 10-yard parallax adjustment ensures precise close range shooting. One of the Match Pro’s more notable features is the Deploy Reticle, which is composed of an precise free-floating dot in the center of a fine crosshair for exact shot placement, and a lower pyramid structure of hashmarks and holdover points accommodates bullet drop and wind drift at extended ranges. In addition, the Match Pro 6-24x50mm Riflescope’s lenses are made from precision-ground glass with ultra wide-band multi-coatings to reduce flaring while simultaneously enhancing light transmission. Furthermore, the Match Pro 6-24x50mm Riflescope’s lenses are given an EXO Barrier for protection against rain, mud, dust, and other debris.
Features of the Match Pro 6-24x50mm Riflescope:
  • First Focal Plane - Reticle holdovers are always accurate no matter what magnification you're on.
  • Parallax goes down to 10 yards - Engage even the closest targets match directors throw at you.
  • 10-MIL Turrets - Simple base-10 system for fast counting and dialing on the firing line.
  • 18 MIL travel windage & elevation - Allows for a 25-yard zero with a 30MOA base on most rifles while leaving enough working travel to be successful with match ammo.
  • Tool-less Turret Reset - Fast & easy reset without needing to remember tools.
  • Deploy MIL etched glass dot reticle with elevation & windage holds - Holdover up to 15 MIL elevation, 10 MIL windage
  • Large, locking turrets with tactile, positive clicks - Confidence-inspiring turrets won't move under harsh stages, bumps, or scrapes. No guessing what setting you're on.
  • Reliable, repeatable tracking - 1/10th of a MIL means just that – No more, no less.
  • Precision ground glass - Fully multi-coated and featuring our Ultrawideband Coating for increased light transmission, color, and contrast while also reducing unwanted flaring.
  • EXO Barrier - Keeps dust, water, and fog off the glass to give you a competitive edge.
  • Rugged Construction - A centerfire scope, it's recoil rated to the same levels as Forge & Elite Tactical XRS II.
  • The best NRL22 Base Class riflescope - Perfect for NRL22 Base class at its price.
