Actually, everybody does not know that the bushwacker is not a machete. Busse should, and probably will (eventually) fashion their own version of the 'cane knife', one where the extra reach is a welcomed. If you have never seen the speed at which a machete can be wielded, you've been sequestered in some dimly lit room behind your plastic pc keyboard for an interminable amount of time. And if you believe that the bushwacker is celestial bliss in the chopping department, let me unceremoniously head you off at the pass. The bushwacker is a good looking 'in between' tool which will be lighter in the mit than the BM, and the resultant celerity will delight many of those that lack the upper body strength that a heavier knife requires. It is, however, no machete.
While I do collect and use Busse knives of all sizes and shapes, the simple machete just keeps plugging along and fills the role as the perfect survival blade for countless people on this spinning ball. As I've said again and again, a properly honed machete is almost unmatched in the hands of a pro for any given task. There are times when a smaller, bowie style blade may be preferred, such as the basic 9. For the heavy chopping chores, I utilize the power of an axe. Clearing brush and vines is where the machete shines. Of course in the nations of central america, machetes are used literally for EVERYTHING one can possibly imagine. What you won't see is some poor guy in Roatan using my eleven and a half inch BM in his cane field or around the field shed in the winding hills of his verdant hamlet.
Machetes see use in Africa in the butchering of all manner of game. To witness a guide use one is a thing of beauty and will cause you to change your opinion of these lowly tools. If you ever really get a decent example (with a proper handle) and use it, the amazement will linger for days. If you grasp the proper technique, you can make quick work of most trees, not to mention keeping the wayward serpent at bay. Even the most treacherous biped will shun a confrontation with someone armed with an 18 inch machete. That being said, I suspect that Busse will deliever such a knife if more people ask them to make it: I would buy one.
