Bamboo is a grass.
Structurally bamboo has a very high strength to weight ratio.
A tube, like a piece of metal pipe, will bend over longer lengths, even just under it's own weight. The thing that makes bamboo strong are the connected sections with the partitions, that is what makes it extra strong.
I really liked the split Bamboo used as a water trough, great!
Pict, that stalk you are touching is awesome, the girth is amazing!
OK, something I learned long ago, and it is actually survival related. :thumbup:
You can make a water tight storage tube out of bamboo.
Cut some sections, just below each partition. Take a measurement of outside diameter, as compared to inside diameters, and with no more than a little shaving and smoothing, you can make a tightly fitting "telescoping" storage tube by slipping a larger diameter over a smaller diameter section.
You can store water in the sections, or keep items dry. Don't hammer them together, it'll be the dickens to get them apart again. Push them together with a twisting motion. To loosen, pull while "un-twisting".
And, remember, it's gonna be tough to find a better "ready grown" survival fishing pole than a nice skinny piece of bamboo. :thumbup:
