Busse ASH1 drill the tubes! Add the screws!!
If for no other reason than they look cooler. :D
Doesn't that void the factory warranty? My Air Force friend wants to replace his tubes with Screws, and I do like the look better, but I like the Nuclear warranty with my INFI...for all that Busses probably need a warranty less than any other knife I've owned.
--BubbaThud
i'm pretty sure drilling the tubes out would not void the warranty...
Busse warranty has no value to me. The knives don't break doing the tasks I do with them. If they did I would not buy them. :D
Bubba,
Some of the things I have personally seen you do with/to your knives would make normal knife makers "Void" in their pants.
Do not worry, it will only void the handles staying fastened portion of the warrenty.
--BubbaThud
I would agree with papathud, the only thing it would void is the tube fasteners, but I'm sure that for a small fee they would put new tubes back on it. unless you modify the scales, I'm sure they and the knife underneath are warranteed against breakage.
Tubes are OK but I like the screws so much better. Thanks for the info! I've got several new projects in mind now!
Anybody know if the scales on a given model are all interchangeable ith others of the same model? Or, are the holes and overall size/shape slightly different? Like between all FFBMs and/or CGFBMs?
I was considering doing this same thing to my NO after several hundred throws- many of which were, ummm, bad (it is bad when a piece of steel over 1/4" thick vibrates loud enough to hear 25 feet away, isn't it?)- caused the scales to loosen up a bit.
But, I like the way it looks with the tubes so, instead, I just got some nuts and bolts and macgyvered the tubes right up. Worked like a charm.
That ASH1 does look cool with the screws though. :thumbup:
Totally voids the warranty and makes the knife virtually worthless.
Send it to me and you won't have to suffer any more humiliation. :D
Actually, it looks pretty good with the mod. :thumbup:
Will the screws hold as well as the tubes? I would think so. It looks great. Thanks.
I don' t think the screws are as strong as the tubes. However they are more than strong enough. Strength beyond what is needed is superfluous and of no value. I do value being able to remove the handles. Additionally the screws look better. Others may use their knife handles for things that need more strength. I am not sure what kinds of things that would be. I know my hand will let go long before these screws do.
Were the slabs originally glued, or just held by tubes?
No glue, just tubes of a very mild steel that drills out with little effort.
