jarrode93@gmail.com
Banned
- Jan 1, 2005
Thank yall very much, yall are very kind. This is a whole lot better than knife forums. I will post at knife reviews and testing. Also, what would yall say about Mercworx????
t1mpani said:There isn't much information available out there on the actual use of Mercworx fixed blades. I'm sure they are extremely strong, since as SethMurdoc says that have very narrow primary grinds and are full thickness for most of their blade. For those who like to throw the "sharpened prybar" phrase around, this is actually much closer to the mark on these than the full or 3/4 height flat grind Busses. Their steel choice for a big, hard-use blade is not the best but they're massive enough (with likely highly obtuse edges) that they probably are fairly tough.
yoda4561 said:T... Strength= absolute resistance to bending, IE: how much force you need to make it bend at all(A1 >/= Basic). Toughness refers to how difficult it is to break by smashing it with a hammer or equally massive and hard blunt object(basic>A1). And Ductility is how far it'll bend before it finally snaps in half (basic>A1). .
Cobalt said:It's amazing how knife design makes such a difference in strength. If you need stain resistance and want strength you need to pay attention to design. Which is what they seem to have done, kinda like Falkniven. Good work IMO
t1mpani said:If strength, hard useability and stain resistance are Mercworx' primary concerns, they could make the same knife with the same grinds out of AUS-8 or 440B and acheive it better. Either of these steels can take hard impacts and lateral stress much better than 154CM. This latter picks up some advantages in edge retention when doing lots of abrasive cutting, but when going from 1/4" thick blade stock to cutting edge in the space of about 1/2" of blade width, I'd think the edge is so obtuse that long term cutting isn't likely to be much of an issue---they won't be able to do it very well from the get-go, so how well the edge is retained becomes a tad moot.
wasn't s30v a spy plane that was removed from actionjarrode93@gmail.com said:What would yall say about S30V????? How would it stand up against 154CM in regards to prying, cutting, chopping, etc.????
Cobalt said:Agreed, but I would rather have the extra edge holding of 154 cm than 440B. Prying strength is not going to be much of an issue on a 1/4 inch blade that is full thickness most of the way down. Kinda like the old Timberline Specwar, which was a brute. Doubt you could put enough force n one by hand to get anywhere near breaking it or even bending it.
idahoskunk said:wasn't s30v a spy plane that was removed from action![]()
