Why would a BB finsih require any added care than satin? in terms of corrosion resistance of course.
To the naked eye, bead blasted finishes look complete, but alas, they are not. Small microscopic pieces of the blade steel are not coated when a knife is bead blasted( The BB coating misses small areas). So when the knife is exposed to the elements, these areas that were "missed" during the finishing process rust, and created little specks of rust on your knife!
Additionally, there is more actual surface area on a bead-blasted knife. Instead of a smooth, flat surface ... you have little hillocks and valleys. More surface area = more steel available to form rust. Additionally, it's possible to retain moisture in those valleys.
See? Not complicated at all. Quite common-sense, really.
Geeks....
Still not there. So, what rust inhibitive qualities does a satin finish posses over a BB finish? I'm "crystal" on the "physical" differences.
In theory, your post makes sense. In practice, I don't find that to be true. There is some element of passivation that occurs due to the second media blast (hence the "double" in DCBB) that makes such a finish very corrosion resistant. My big user ZTSH has all sorts of smoothing scars in the DCBB but rust has never made an appearance.
Isn't satin a finish achieved by polishing? I understand BB will not be as uniform.
So, where do the corrosion resistant qualities of the steel come into play? Satin or BB, same steel.
Disclaimer: my experience is with SS 1911's with polished flats and BB rounds.
It is the same steel. But the more polished surface gives less "traction" for the water or corrosive agents to get into.
If you have ever had high carbon steel. You will notice a real difference in how the exact same steel reacts with different finishes. A mirror polish will resist rust better than a rough finish, or bead blast finish will.
If you have ever media blasted glass, and then gotten the glass wet, it does not bead water off any more. Even if you wipe it with a dry rag, it will retain a bit of moisture, and will hold it much longer than than smooth glass.
With bead blasted steel, If you look at it under very high magnification, you will not only see high spots and low spots (think mountains and valleys) but you actually get metal pushed over micro holes (like caves). When being struck with high speed impact material (like bead blasting), the metal will actually push and become plastic at the very surface. The blasting medium acts like hundreds of thousands of meteors striking the surface. It is on such a micro level that you can't tell with the naked eye.
Another analogy is to take hard packed soil. Dump water on the soil. It will run off pretty quickly, and not absorb very deeply.
Take that same soil, and cut deep grooves in it with a plow. Dump water on it, and the water has some place to sit and collect in the grooves (like lower grit finish steel). Or, take the same dirt, and poke hundreds of thousands of holes in it, and the moisture has a place to pool.
The same thing goes for acids and moisture and salt in your fingerprints (or what ever you get on the blade that has potential to cause rust). Mirror polish will be easier to keep rust free, and easier to wipe stuff off.
It is still Infi, and the great thing is that even if you are able to get Infi to discolor or show rust, it is not a deep pitting rust like you will get with higher carbon steels!
