- Aug 13, 2002
To help transition back into the shop after a long time doing almost nothing knife wise, I thought restoring this old knife would be a good idea. From what I gather it dates from the beginning of the 20th century, 1919 or so.
The blade itself I know how to fix but the handle is where I am not sure. As you ca see, water got under there and there is major rust.
Popped off the scales and as you can see, not pretty.
But look at that. A distal taper in the blade and even a tapered tang. Don't see much of this in production knives these days.
Now is where I am not sure. As you can see, the scales shrunk. Cleaned up the tang a little and you can see the difference.
So do I reshape the tang to try and use the same scales or do I make new ones? Maybe even with really modern materials, like a mix of old and new. Or go for a more traditional look and try with plainer wood.
What do you think?
What do you think?
