bzzhewt said:
I could not get a shaving edge from a coarse stone ...
There are lots of things you accept as impossible until you have seen it.
I thought ~125 g on light thread was acceptable for sharpness until I tested a bunch of Spyderco's which made me realize my standards were way too low. Now I look at ~90 as decent, and only really see ~75 as acceptable.
I have seen shaving abilities on really coarse edges, it is just a matter of getting the edge alignment and extent of grinding. There are people who can file edges and shave smoothly with them.
Phil Wilson for example prefers the edge the Norton x-coarse SiC hone leaves on his edges, it is
very sharp, he has no burr problems though as his steels are usually harder than average at 60+ HRC.
[high burr angles]
... I just seem to be dulling my knife
Even very high angles can be sharp, they don't of course cut as well as low ones, but they should still slice paper and shave easily, again it is in the alignment.
..Im not seeing a burr at any stage after using these steps, EXCEPT after i progress from my finest stone to my triangular ceramic rod!!!!
To be clear here, how sharp are the blades before you go to the ceramic rod? It is pretty common for ceramic rods to induce burrs, I found when sharpening Randalls for example that it was easy to get a nice crisp edge on large benchstones, but as soon as I tried to apply micro-bevels with the Sharpmaker it was
very difficult to keep the edge crisp. The steels are just too soft to deal with the high pressure created by the low contact areas.
If you are not getting a full crisp edge with the x-coarse hone then the very edge isn't getting hit by the abrasive and thus there is metal left there which has seen extensive use and is likely weakened from fracture or plastic deformation. Thus if this metal finally surfaces on the finer hones, likely just from the repeated abrasion, the resulting edge will be very prone to burring and resisting forming a crisp line.
...this leaves my actual cutting angle when i whittle or cut anything waaaaaaay too high for me, plus, any ability to shave or slice paper is gone due to the blunt edge!!!
I can understand the first, but the second indicates an odd problem. If I had to guess I would say the edge is cracking off. Does this happen on more than one knife? Can you check out the edge under 10-20 magnification?
Could it be that my ceramic is just too worn out to be effective at cutting??
If it was perfectly smooth, it would just act as a smooth steel, which would induce a burr but it would not dull the edge unless you used a lot of force, plastically deformed the edge and then it fractured.
What you are sharpening by the way in softer stainless are one of the worst steels to form into a very sharp edge. It is like trying to give a tomcat a bath. Some things can be an exercise in frustration. A really nice steel to sharpen is 52100 at ~60 HRC.
-Cliff
