Buying my first grinder, need advice please!
Hi guys, i've been thinking of getting into knife making using flat stock, shaping it and making handles etc, i was wondering if a cheap little grinder like the one in this link would do the trick, any advice would be greatly appreciated!
http://toronto.flyerland.ca/products/canadian-tire-mastercraft-1-in-belt-disc-sander-product-10457835/stationary-sanders-category-2035
Back in late 09, I bought a new Kalamazoo Industries 1x42 grinder. It has a 6" grinding stone on the opposite side of the motor. I think I paid around $300. That is the only grinder Iown and it has paid for itself many times over.
The sander that you show should work, but if you're serious and want to spend a little bit more, I have a Kalamazoo 1x42" and really like it. Enco has the cheapest price that I've found ($216.95). I received the following email as well today. This will save you 10% plus the $20 shipping charge. I wish that I could have had this deal!
"Happy Memorial Day from Enco! This week only, take advantage of our double offer: 10% Off + Free Shipping*
Use promo code: MCTN for 10% off* your entire order of $99 or more - no exclusions; plus promo code: MCFS for free shipping*! To take advantage of both offers, be sure to enter both promo codes prior to checkout. Simply enter promo code: MCTN (then click apply) for 10% OFF, and then enter promo code: MCFS (then click apply again) for Free Shipping!
Hurry! This offer ends Monday 5/28/12!"
http://www.use-enco.com/CGI/INSRHM
Good luck!
I just requested a catalog.
I use the grinder that you have shown and it works very well for me. I love having the disc on the side its great for so many things
I've used my 1x30 HF grinder extensively for putting handles on knives. It worked very well and I've started using it to grind knife blanks. It works OK but it is also slow compared to the Kalamozoo noted above. You should heat treat whatever blades you make unless they are just for practice. Mill steel; 1018 and 1036 make really poor knife blades.There is a LOT of good information on the Shoptalk / blademakers forum you might check them out.
Note that I am using pre made blades on these.
If you have a very small budget, get a sears 2x42. Stay away from the 1x grindersfor stock removal. You can get the sears 1x42 on sale for around $140 and just get a ceramic platen for it and you will be set.
An underpowered 1x30 will allow you to get started, but it definitely has limitations. I still use mine for some things, but by and large have set it aside.
When I was using my 1x30 at its peak, I used it (and a bench grinder) to profile the blade, files to do the bevels, and hand sanding paper/blocks to clean up the blade. In other words, very little blade work was done on the 1x30. But when I started working on the handles, the 1x30 came back into service.
The problem I had with it is that for me at least the platen on those things isn't useful for bevels. It's too small and the opening around it is too constricting. Invariably, I would end up cutting deep grooves in the bevels because of the awkward way I had to move the blade to do things like cutting in the plunge. The unit is just too enclosed and too much of the sanding surface is inaccessible during operation.
On the plus side, there are a lot of belt types and grits available in that size... but on the down side, they are not all created equal. I found it quite annoying when belts generated a bump at the join, causing the blade to jump every time the join rolled by. I haven't felt this on my new grinder.
So, if that's all you can afford, go ahead. But if you're like me you'll find that it alone is not enough, and then you'll end up spending more on files, other sanders, and so on.
