C101GP Manix 80mm (smaller manix)
This one is hard to find. The knife is in immaculate condition and the Manix you want/need for your collection. Asking $200 NET (add 3.5 of use friends and family with confidence).
I paid a hell of a lot more but need to cash out as my priorities are elsewhere. I'm selling a Spyderco Manix C101GP 80mm Straight Edge. This is not the Manix 2 but the original Manix. The blade itself is made of CPM s30v steel. The handles are black G10. The lock is a mid lock-- and this bad boy really walks & talks! This knife locks shut with more authority than any Spyderco I've ever owned. This knife has been sitting in my safe new and unused and it's time for someone else to enjoy it. Never sharpened or carried. The blade is not perfectly centered but very close. The knife comes with the original box.
Knife Specs:
Overall Length: 7 3/4 inches
Blade Material: CPM-S30V
Blade Length: 3 1/4 inch
Manix 80mm by Albert Berry, on Flickr
Manix 80mm5 by Albert Berry, on Flickr
Manix 2 by Albert Berry, on Flickr
Manix 3 by Albert Berry, on Flickr
Manix 2 Dark Blue Lightweight CPM 110V Asking $120 NET (add 3.5% or use friends and family)
The Manix 2 Lightweight CPM S110V combines the ultra-lightweight construction of our award-winning Manix 2 Lightweight with a blade ground from premium Crucible® CPM S110V. This state-of-the-art powdered metallurgy steel contains high amounts of vanadium and niobiumalloys that give it exceptional wear resistance and higher corrosion resistance than many other stainless steels. The rest can be found on Spyderco's site.
Untitled by Albert Berry, on Flickr
Spyderco Manix 2 XL C95CFP2 S90V Asking $280 NET (add 3.5% or use friends and family) - Lanyard NOT included.
Only 800 of these made. The large Manix2 is an oversized version of the Manix2 with a blade that is just under four-inches. The blade is locked open using Spydercos patented Ball Bearing Lock. The lock is comprised of a free-floating steel ball-bearing encased in a high-tech polymer cage. When opened, the ball bearing moves forward onto the blades ramp where it is wedged, locking the blade safely open.
The spherical shape of the ball rotates freely allowing the lock to self-adjust across a large surface, ensuring smooth and confident lock-up every time it is opened. The blade is CPM-S90V, ground full-flat and features jimping above the oversized 14mm Spyderco Round Hole. The jimping texture continues from the blades spine to the full-length skeletonized steel liners.
length overall 8.94" (227 mm)
length closed 5.1" (130 mm)
hole diameter .56" (14 mm)
blade length 3.86" (98 mm)
cutting edge 3.44" (87 mm)
blade thickness .125" (3 mm)
blade steel CPM-S90V
weight 5.9 oz (168 g)
handle material Peel Ply Carbon Fiber
Manix XL2 by Albert Berry, on Flickr
Manix XL3 by Albert Berry, on Flickr
Manix XL by Albert Berry, on Flickr
Manix XL4 by Albert Berry, on Flickr
Knife Specs:
Manix 3 by Albert Berry, on FlickrManix 2 Dark Blue Lightweight CPM 110V Asking $120 NET (add 3.5% or use friends and family)
Untitled by Albert Berry, on FlickrSpyderco Manix 2 XL C95CFP2 S90V Asking $280 NET (add 3.5% or use friends and family) - Lanyard NOT included.
