C69 - new "wonder" steel in WIRED magazine
Rob was nice enough to send me a slab of the super material he is working with.
Cant wait to get it into a blade.
The end result sound great so far!
Thanks Rob.
We used to get (as stated above ) .08 depth of carb on gear teeth using 8620 and 9310 .
The core was toughened first ..They worked well.
Nitride was great for high speed gears with light loads. The rc was 72-74 rc. They chipped when dropped.
I would like to see this blade chip tested.
It would be great if there is no chipping.
Hum ????
Wouldnt want to sharpen it.
Web Site At www.darrelralph.com
MADD MAXX !
Darrel, some interesting observations there!
I have to say I'm starting to come around to the notion of carburizing for knives. My fear was that the case depth would be too shallow. I believe this is remedied by doing a diffusion heat treatment after the carburizing (what is referred to the the QuesTek .pdf as "a typical boost and diffuse cycle").
Their .pdf files are here, hopefully I can get the hyperlink to work this time...
http://www.questek.com/questekalloys.html
This spreads out the carbon over a deeper zone and prevents the surface from getting too much and thus remaining too brittle after the subsequent tempering. It becomes a matter of proper heat treatment design for the alloy at hand: carburize for the right time to inject the right amount, then diffusion anneal for the right temperature and time to get the desired concentration profile, then temper properly. Classical ferrous metallurgy!
What's said here goes as well for nitriding and carbo-nitriding. Nitriding would have the additional bonus of being less detremental to the corrosion resistance of a stainless steel. The over-hard case surface Darrel mentions on nitrided gears can be softened by a suitable post-nitriding diffusion treatment as mentioned above.
What are the broader rammifications of this? Namely it opens up one's choice of materials. Rather than worry about the hardenability of a particular steel, you can choose one that is tougher and/or easier to work with and then tailor the hardness/impact resistance balance at the edge through the case hardening and heat treating design. There are steel alloys out there like Ferrium C69 that are strong and tough and would take well to this processing. Essentially look at gears being made for aerospace and high-end automotive use and you'll find examples. Yes, work on lightweight heavy-duty gears is what prompted QuesTek to develop a material like Ferrium C69 (note: the same composition is sold by them under the name GearMet C69!).
For you traditionalists out there, a carburized knife profile is similar to the Japanese lamination technique called 'makuri'. http://japanesesword.homestead.com/files/nihonto.htm
The downside to this is that good carburizing/carbonitriding/nitriding is really something best left to pros with the capital... and you'll be giving up having your eyes and hands involved with every step.
Any thoughts?
[This message has been edited by GrantP (edited 01-24-2001).]
[This message has been edited by GrantP (edited 01-25-2001).]
My question is will the OLD STYLE induction harden (edge only), on a blade (of 9310) leaving the core at say 45rc, then the edge at 62 rc work well.. Should make a very tough and hard and blade.
Always wanted to do it but just have not had the interest. I like 9310. Tough stuff.
C69 sounds great. Still a bit hard for a blade im sure. After heat treat even if the edge was on before heat treat, it would have to be sharpened. This could be a job.
Does the c69 come in thin stock . What are the shapes? The link does not work.
MADD MAXX !
[This message has been edited by Darrel Ralph (edited 01-25-2001).]
Well, I chased down the Cronidor folks in Germany and learned that it is available only in rods, unless you want to buy a sufficient quantity for them to roll some. Here's what they said:
"Thanks for your inquiry. At present our stock program consists of round bars, annealed, centerless ground or peeled dia. 4 mm, 4.5 mm, 10 mm and 50 mm.
In approx. 4 months we will have additionally available dia. 5 mm, 5.5 mm, 6 mm, 8 mm, 15 mm, 20 mm, 25 mm, 30 mm and 40 mm.
Sheets would have to be manufactured to order (minimum quantity presently not known). Please inform quantity required (of interest)."
I'm probably not going to write back saying I want a bar of 5mm stock, 2" x 36".
What are the chances of getting someone here in the US to forge some rods into billets?
Jerry Hossom
www.hossom.com
The New Tom & Jerry Show
OK, I've plowed through this thread, and my little aero engineering pea-sized brain is having a little bit of a hard time following all of it.
Or maybe it is all the Yeungling Lager last night
... but anyway....
Bottom line it: are we looking at a possible CPM killing alloy/treatment here?!
I've seen a look in dogs' eyes, a quickly vanishing look of amazed contempt, and I am convinced that basically dogs think humans are nuts. -- John Steinbeck
Dog does not eat dog. - Juvenal
iktomi
I called and talked to Kevin Cashen yesterday and he told me that this stuff is real and he also told me it is not something that is going to be pleasurable to work with. Sort of like that blade that was forged out of stellite in the knife mag article. This stuff is also not being designed as a knife steel, but some other industrial application.
Danbo, soul brother of Rambo
Darrel: I fixed the link. QuesTek's ph# is (847) 328-5800. You'll need Adobe Acrobat or the like to read their info sheets. As for 9310, maybe you could flame harden the edge for simplicity's sake? Just some musing on my part.
Rockspyder: This thread has indeed gotten rather convoluted. For one thing I brought up another alloy that interests Jerry, Cronidur 30, that is unrelated to the Wired magazine article. Then I got professorial about case hardening, which may not have helped anybody. The bottom line with regards to Ferrium C69? That's up in the air. It depends if the edge developed on Ferrium C69 will chip during use or not. The test shown in the magazine, while impressive in displaying the strength and hardness, does not include impact or significant lateral forces that would be the downfall of a brittle edge.
Danbo: Gears!
Russ: tiring of getting these posts in your mailbox yet?
