I'll explain my whole process if you guys don't care and let me know if I'm on the right track. The cable I have is pretty greasy so I first burned the grease off in a fire letting the cable get red hot then I let it cool back to black and quenched it in warm water with some borax mixed in (I read somewhere that this will break up some more gunk). I welded up both ends with some rebar on one end for a handle. In my propane forge I brought the piece up to dull red then fluxed. Brought piece up to high yellow (took around 10 minutes) and twisted. I wire brushed, fluxed, heated and twisted again. Wire brushed, fluxed, heated to high yellow but only soaked for a minute or so and began to hammer at the tip while turning cable so not to unravel. That first round the tip was in a tight solid round bar. I repeated with wire brushing each heat but at this time I had a hell of a lot of flux built up in the cable so I fluxed about every other heat. I worked the cable into a round bar (stopped fluxing) then square and finished off hammering it into a flat bar. Hey thanks guys again for all the help. I'll try some pipe here soon and will clean better and soak longer. If you fellas have anymore suggestions I'd be grateful to here them.
