I just had to jump in on this one and put in my two cents worth. I believe there is a BIG misconception out there concerning cable (wire damascus). Many believe they should start with it because its easier than laminated steel.... not so. It far easier to be successful with laminated/layered damascus than it is with cable. Think about it, with cable you have a bundle of round wires, all of which your trying to weld to each other. Since each wire is round, they want to slide/slip past and over each other rather than weld together. Because of the configuration of the individual wires (layers) specific forging methodology is required to make it work. More times than not you wind up with voids, inclusions, and cold shuts. Not only is this due to the configuration, but if your trying to weld used cable, you've got all the crude, grease, oil, and gunk hindering your efforts. To top it all off, most are never sure of exactly what type of steel is in the cable their using, so now theres another variable to overcome.
Compare that to welding straight laminates of two know steel types. Each layer has a flat mating surface, which doesn't try to slide past its mate, its not that difficult to learn to gently hammer the billet at the start, and increase the power of your blows as it welds, and you finally, you don't have all the gunk hindering your efforts.
In the past we have looked upon cable as an easy and cheap way to make a type of "Damascus", which was my mindset for a long time. After realizing all the failures associated with cable, and all the problems it presents, especially to less experienced forgers, I try to steer folks away from beginning with cable, and recommend they start with laminates. The chances for some initial success are much greater.
