Cool. I can't see the scale... if I zoom in, it's just a blur.
I suspect (theorize?) that such a small section may be part of the reason for the difference here.
I actually think that might be the reason for the difference. Even the Sharpie testing might not pick up a change in such a small area, and even if it did, it could be easily compensated for, without even realizing. Have to give that some thought.
... Is there a backing plate behind the point of contact on the belt (like your typical bench-top 1" wide belt sander) that you have removed, or is there just not one in the first place?
If there isn't one, what if you added one, to essentially set a stop on the peak belt flex? ...
Theory proposes, experiment disposes. Let's start with theory:
Consider a thin blade having an edge apex angle of 37 degrees inclusive being sharpened in the WSKO-BGA. The blade is kept horizontal at 0 degrees, and the tool is set to a belt angle of 10 degrees, with the intent of achieving a new blade apex angle of 20 degrees inclusive.
Start with no contact between the blade and the belt:
Now bring the blade towards the belt, keeping the blade at 0 degrees, until the blade just contacts the belt. Contact will be made at the shoulder of the existing edge:
As the blade is pushed against the belt, the belt begins to flex:
As sharpening proceeds, steel is removed from the blade, and the sharpened region gets wider. This continues until the sharpened region hits the apex:
The blade is flipped over, and the sharpening process is repeated on the other side:
The final edge geometry has an angle of 15 degrees inclusive at the edge shoulder, and 24 degrees inclusive at the apex. The inclusive apex angle is 4 degrees greater than the intended target.
Now let's repeat this exercise for a thicker blade, with the same initial edge apex profile, and keeping the same 10-degree setting for the tool.
The final edge geometry has an angle of 17 degrees inclusive at the edge shoulder, and 37 degrees inclusive at the apex. The inclusive apex angle is 17 degrees greater than the intended target.
So much for theory. Now, experiment disposes:
This sample shows my sharpening results for an Opinel no. 8, made from thin blade stock (0.07 inches thick.) The WSKO-BGA was set to 15 degrees, so we should expect a nominal edge angle of 30 degrees:
For this thin blade, the offset between the tool setting and what I measure as the inclusive apex angle is 3 degrees.
This sample shows my sharpening results for a Suwannee Lime Cutter, made from blade stock of thickness 0.14 inches, which is twice as thick as the previous example. As in the previous sample, the WSKO-BGA was set to 15 degrees, so we should expect a nominal edge angle of 30 degrees:
For this thicker blade, the offset between the tool setting and what I measure as the inclusive apex angle is 6 degrees.
From these results, I conclude
I'm afraid this means there can be no simple answer to the question "To get an edge angle of X degrees, where do I set the tool?"
- The convex profile of the edge formed by the WSKO-BGA calls for careful definition of, and control over, how the edge apex angle is measured.
- For a given tool configuration, different blade thicknesses will result in different edge apex angles.
... In your first example, if the belt didn't flex at all, then when you reached the apex, you'd have a 10 deg. apex. But when you add the belt, you seem to flex the belt until you manage to thin the shoulder, but still maintain the 14 deg. (28 inclusive) angle at the apex ...
... Not really how it works.
... what I see is a knife that has been totally reground... totally independent of any part of the original blade. None of your dotted lines (in the 2nd to the last picture), match with any part of the original blade. I think in theory, all you did was grind a new knife. That's what it looks like to me anyway.![]()
I'd expect some variation in amount of convexity/deflection based on belt speed as well. Slower speeds will tend to have more deflection at the same amount of applied force.
