Calling ED! (Esav)
That's AM broadcast, FM broadcast, shortwave broadcast [in the bands listed]. Does not include amateur radio bands.Can't tell you about the sensitivity.As components get smaller and smaller so do the radios !
So, not taking into consideration signal strength, this radio could not pick up, say, The BBC?
I just took the radio out to see what I could pick up. One battery leaked and the whole unit is FUBAR. I guess I better send in an order for a new one. Grrr ...
I am sorry for your loss friend. Perhaps we need to cremate that thing. I had a really nice LED flashlight die on me once because of the same problem. I won't use any battery for long term storage unless it is Energizer.
What type were you using in your's Ed?
Fantastic little radio. I've had one for several years.
Like ALL shortwave receivers, the reception on SW bands is greatly increased by adding a long wire to the antenna. A simple length of insulated small gauge wire with an alligator clip on the end will do the trick. That same wire can be used for traps, snares and emergency repairs. Night time reception is best. I string the wire between my hiking poles or to a tree branch to my radio and clip it to the end of the telescoping antenna. CountyComm does sells a handy-dandy retractable long-wire antenna too.
DO NOT run your long wire in conditions where there may be lightning storms. I would avoid ridge tops above tree line, etc. Static build up is possible with a long wire antennas too, which can cause problems with the radio and give you a buzz-- Ben Franklin flying a kite kinda stuff. Don't be the key :)
Add an Aloksak bag or other waterproofing. A small Rubbermaid box would work well. The CountyComm box is good for keeping it clean and knocks, but it's not waterproof. Leave room for a couple spare batteries. I like a little mini earphone too, rather than the speaker for increased reception and less power consumption. The speaker is fine for it's size. It has a clock too. Also, keep in mind that it has an analog tuner with a digital readout. Fine by me, as you can split hairs on reception.
The LED light is very usable and handy as a tent light, although you can't run the light and the radio at the same time.
Catching the BBC broadcasts is very possible, but reception varies with location and conditions. It's amazing what AM stuff you can catch at night in wilderness areas.
Give this radio a two thumbs up. IMHO, the next step up for size and reception is about 5x the price.
I just ordered a new one. I rarely have battery leaks so this really surprised me, and only one of them did so. Duracells. Coincidentally, I have a pack of Energizers now.
Shortwave is fun. I have a Radio Shack desk radio with SW that I think is actually a Sangean. On a good night I get around the world reception. So the little County Comm didn't get much of a test. :)
Edit: I don't know if I ever mentioned this, but there is a Russian language broadcast somewhere near here. Russian is like American English: it is NOT a clearly enunciated speech. But the radio's speaker is so good, I was able to follow them pretty well.
