- Jul 8, 2008
Here is a good looking, traditional type edc, only with a kydex sheath for neck carry.
OAL- 6 7/8"
blade- 3" long, .115" thick, 11/16" wide at the guard
steel- High Performance 1095, with in-house differential heat treatment which includes double normalize, double anneal, double edge quench, and triple draw, for a high performance blade, that holds a great edge, and yet is easy to sharpen!
grind- a full flat grind, sharpened on a Norton Fine India stone with micro bevels, to an agressive razor edge
finish- etched 400 grit finish, with hamon or temper line.
handle- a great piece of curly maple, dyed with pertassium permaganate, with a tung oil finish, and blue spacer
guard- 1/4" brass guard, nicely contoured to feel good on the finger, for greater control, and saftey in challenging situations, and 1/8" brass pin
sheath- .060 kydex, with a "snap fit". Sheath holds blade securely even when upside down, yet allows instant draw, come with a black beaded chain for neck carry
weight- 4-5 ounces for the whole package of knife, sheath and chain
blade fully tested for edge retention and tip strenth before finishing! The blade is subjected to an edge flex test, where the edge is flexed over a 1/4" brass rod from both sides to check for toughness. These blades will generally make 130 {at a minimum} slicing cuts in 1/2" manilla rope in my shop on a scale, without requiring more than 35lbs of force to complete each cut, and will typically still shave hair from my arm at the end of the 130 cuts! {your performance may vary due to rope consistancy, sharpening teqnique, sharpening stone condition, and cutting skill}. The heat treated blades are dropped point first on a concrete floor from a distance of roughly 4 feet before finishing, the blade must exhibit no substansial damage to pass the "concrete floor test". After a blade passes these tests, only then does it go to the finishing stage.
$120 plus $10 for shiping/insurance to CONUS. I can accept paypal Joe357m@bresnan.net or money order.
SOLD!!!
1st to post "I'll take it" gets it!!!
Ships within 48 hours of payment priority with ins.
Feedback appreciated, and thanks for looking!
If you would like one like this one or different, PM or email with details!
OAL- 6 7/8"
SOLD!!!
