Calton 1095 and Olivewood edc/sgk!!
Feedback: +54 / =0 / -0
OAL- 6 7/8"
blade- 3" long, .135" thick, 13/16" wide at the guard
steel- High Performance 1095, with in-house differential heat treatment which includes double normalize, double anneal, double edge quench, and triple draw, for a high performance blade, that holds a great edge, and yet is easy to sharpen!
grind- a full flat grind, sharpened on a Norton Fine India stone with micro bevels, to an agressive razor edge
finish- etched 600 grit finish, with hamon or temper line.
handle- a nice piece of olivewood, with a tung oil finish, and black paper micarta spacer
guard- 1/4" brass guard, nicely contoured to feel good on the finger, for greater control, and saftey in challenging situations, and 1/8" brass pin
sheath- 9-10 ounce leather with a cam for a "snap fit". Sheath holds blade securely even when upside down, yet allows instant draw. light tooling
blade fully tested for edge retention and tip strenth before finishing! The blade is subjected to an edge flex test, where the edge is flexed over a 1/4" brass rod from both sides to check for toughness. These blades will generally make 130 {at a minimum} slicing cuts in 1/2" manilla rope in my shop on a scale, without requiring more than 35lbs of force to complete each cut, and will typically still shave hair from my arm at the end of the 130 cuts! {your performance may vary due to rope consistancy, sharpening teqnique, sharpening stone condition, and cutting skill}. The heat treated blades are dropped point first on a concrete floor from a distance of roughly 4 feet before finishing, the blade must exhibit no substansial damage to pass the "concrete floor test". After a blade passes these tests, only then does it go to the finishing stage.
$120 plus $10 for shiping/insurance to CONUS. I can accept paypal Joe357m@bresnan.net or money order.
1st to post "I'll take it" gets it!!!
218131095oliveleft.jpg218131095oliveright.jpg218131095oliveblade.jpg218131095olivesheath.jpg
Ships within 48 hours of payment priority with ins.
Feedback appreciated, and thanks for looking!
If you would like one like this one or different, PM or email with details!
Very nice knife for an even better price. I like the performance examples too. Someone will be happy with this little guy!
Wow what a package! Beautiful workmanship and great design. Unemployed, otherwise this would be gone. Obama says the economy is getting better so....yeah, I know, I won't hold my breath.
Thanks guys!!!
knifemack- i got your pp, she will be on her way to you in a few hours!
peri- I will have another one similar to this one up in a day or so.
