I didn't thin this particular one out. I do thin out most of my knives when I get them from the factory/maker. I haven't yet done much cutting with my Krein modifieds, but here are some pictures that can help explain.
Here is a stock Caly Jr. ZDP (burgundy), a VG 10 that I've thinned (grey), and the one I sent to Tom Krein (black). You can see how far my thinning went, as opposed to his re-grinding.
http://i137.photobucket.com/albums/q203/sodak_photos/p1010010-1.jpg
My thinning, while helping, doesn't go up nearly as far. As the knife dulls and I keep re-sharpening the microbevel, I'll need to keep re-thinning. With the primary grind thinned out, that won't be necessary.
To put things in perspective, in order to sharpen, when I've thinned the edge out, I can re-sharpen the knife in under 3-5 minutes on a diamond hone, no problem. That's ANY knife, I don't care what steel is used. With the re-ground edges, I can completely re-set the entire edge (including, of course, resharpening) in 3-5 strokes on a blue dmt stone. No kidding.
You almost have to see it to believe it.
The performance difference is unreal.
Here are a couple of Caly 3's:
http://i137.photobucket.com/albums/q203/sodak_photos/p1010011-1.jpg
and a Cabelas Mini-Grip (in D2):
http://i137.photobucket.com/albums/q203/sodak_photos/p1010017-1.jpg
I feel the need for a disclaimer. The Caly Jr.'s and Caly 3's, in my opinion, are about the best folders out there. Period. They will surpass probably 99.999% of the public's expectations of what a pocketknife should do. They (IMHO) outcut almost all other production folders, and are a joy to use. It is for this reason that I'm modifying them, trying to see if I can squeeze even more performance out of them. Please don't mistake this post as a criticism, it is not. Pretty much nothing else made the cut.
You have these things done to your favorite folders, you will, in all likelihood, incur some damage while using them, until you learn to respect thin primary grinds. You will also come about as close to a Jedi light saber as you will ever be able to do in this life! Enjoy!
