**SOLD**
Nearly new Camelbak Maximum Gear M.U.L.E. hydration pack in three color desert camo. Pack and bladder are both spotless. I have cleaned and disinfected all the water gear. The hose has a bite valve with the neoprene hose cover, a shutoff valve and a bite valve cover to keep it clean and help protect from freezing. The Camelbak Maximum Gear line is heavy duty-- more like Maxpedition and much tougher than the civilian/consumer stuff.
Factory specs:
· CamelBak's MULE is still the most efficient and compact way to carry your water and field essentials. You will appreciate our Independent Suspension Harness during fast-paced, high-action missions – it stabilizes the load as you move. And the Air Director™ back panel keeps you cool as you push onward.
· Use D-ring attachment points to place unit anywhere.
· Includes HydroLink™ Modular Connection System with positive shut-off HydroLock™.
· Nearly 9 L (540 cu. in.) of convenient storage. Perfect for MREs, communications, and first aid.
· Includes OMEGA™ Reservoir – fill and clean easier than ever.
· Easily load your reservoir with our enhanced zipper access.
· Independent Suspension Harness keeps load stable as you move.
· Air Director™ ventilated back panel for keeping cool.
· Integrated MOLLE/PAL attachment system.
· Capacity: 100 oz (3.0 l)
· Dimensions: 18.5 in x 10 in x 5 in (470 mm x 254 mm x 127 mm)
Volume: Cargo Only – 540 cu in (8.84 l) • Including Water – 720 cu in (11.8 l)
· Weight: Empty Reservoir – 1.81 lbs (0.82 kg) • Filled Reservoir – 8.06 lbs (3.65 kg)
Factory specs:
