- Apr 20, 2001
Found this a few days ago new in the knives at my local "Box" store.
AUS8 and G-10, out of the box, it locks up with no play at all, opens very smooth and the factory edge is arm hair shaving sharp.
Liner lock is solid and well done.
Pic' is a little blurry, but it has almost full steel liners nested within both scales.
Lanyard hole is pretty much worthless, you can get something like tarred bank line through it, but it's not even close to being large enough for paracord.
Fairly thick blade stock, with nice jimping.
Up beside an Ontario RAT 1, which is probably the knife this one will be compared to alot. Similar value for what you get.
The only real negative for me here, is typical of bargain folders, they are pretty much right hand knives. The "Hustle" comes setup only for right hand tip down, and there is less clearance between thumb stud and handle for southpaw, BUT the angle your thumb approaches the stud, actually makes it still very usable for southpaws as far as that goes, I can actually open it just fine.
Non-reversible pocket clip aside, I like this one a lot, you're getting a lot of knife for under $25.00.
