- Jan 27, 2013
A carbide tip in NOT required as mentioned above. You can break a glass window with all manner of implements from softer materials. Again, as mentioned above, you simply need a focal point and sufficient force behind it. A smaller focal point demands the less force to accomplish the task. Ceramic carbide is popular because it is inexpensive and resists deformation, maintaining a small impact focal point. But steel will work just fine:
I apologize, I did not mean REQUIRED. I meant that a carbide tip is preferred because you will quite likely deform steel, especially something like a blade. You can break glass with dang near anything, but using a harder material tip will work EASIER.
