Mister Bose speaks on the strength of those shadow pattern bolsterless knives.
I think they are stronger when made with micarta because there is no joint where the handle material meets the bolster. That is the weakest place on a bolstered knife. I've seen old knives that were bent at that point from abuse.You can tear any knife up because they can't be made stupid proof. This type of shadow construction will take a lot.
http://www.bladeforums.com/forums/showthread.php/468281-Bose-Knives?p=4577451#post4577451
The old shadow patterns had a pivot pin going though the handle with a head spun on it or hammered down. They were weak and always developed play in the blade. There was also a birdseye which had a thin nickle silver washer the pin went through which was better, but still not good.
BoseKnives shadow pattern has a 100 thousands thick stainless washer with a tapered hole for the pin that can be really locked down. This washer is counter bored into the micarta and then the pin peened over to mesh where you can't see the pin in the washer resulting in a rock solid pivot. If you break this loose you are doing something you shouldn't be doing with a pocket knife
In-plane, even a cheap knife is stronger than your hand.
Exactly.Great thread.
One quick question?
To tighten side to side play in a slip joint can you just tap the pins in the bolster? Seems like it might just be a cross pin, peened into place, and smoothed over?
I have an old buck lock back that I did this to as a child. The blade developed side to side play after years of use, and I took two hammers laid the knife on the face, and gave some light taps to the opposite side. Tightened the blade play right up, and it is still tight today.
Lets say, for example a bolstered GEC Pioneer etc?
Couldn't agree more. Get a Buck 301, and you'll spend less than $50 for a solid workhorse that will last you for as many years as dollars you spend.I would buy a good quality slipjoint ( you won't have to spend $80- $100 ) for work and carry it with all confidence that it would perform the above mentioned tasks as needed. People have for many decades.
I worked at a carpet store while I was in high school and one of my usual tasks was to trim up remnants, back roll them, and tie them with twine. I think I was using a Valor stockman at the time and after a few months would sometimes do like post #11, photo #2.
I just thought I wore out the knife. Still have it in a box somewhere. Never thought I might have been "abusing it".
I should probably point out that it only does this under pressure. As soon as I let off the pressure the blade snaps back into alignment/normal positioning.
