That eye is deformed from being beaten on while used as a splitting wedge. And with no proper wedge in the kerf I'd be amazed if that axe lasted thru a single day of serious work. Sorry to rain on your parade but that one has seen better days.
I was afraid you would say that, so there is only a quarter inch on each side of the metal wedge, do you even recommend a re-heft or is this one a lost cause?
Good explanation and in your case well worth giving it a shot! But this is not something I am going to write down or memorize as long as there are still lots of decent heads around to be had. As a totally non-nostalgic buddy of mine always says about seemingly disposable goods: "C'mon man, give it up. They make new ones every day".I don't recommend fixing it. But if it has become personal for you and you want to see it hung right then you can fix it good enough with a bit more effort. Here's what I'd do in your place. Get a MAPP gas torch. Tie a wet rag around the bit of the axe about 1-1/2" from the edge. Then heat one side of the eye only of the with the MAPP gas torch until you see a blue temper color in an area that has been sanded or filed shiny. Recall that this axe eye deformed cold. It can be pushed back in at moderate heat with only slight weakening of the steel. Heat it. Hammer it. Go ahead and quench it. You won't make the eye brittle because you never it got it up to the critical temperature for hardening. And you won't ruin the temper of the bit because the wet rag is protecting it.
Once one side has been hammered in, flip it over and do the other side. Heat & hammer. The cold side of the eye won't deform because the hot side will absorb the blow. Metal moves easiest where it hottest. A beginner can do a decent job of repairing an eye in this manner.
Thanks Twoinch, I really appreciate the feedback on the heft, its only my third. I couldnt even fit a wedge in there because it was so tight. See pics. Thanks for all the great help! Im very appreciative!
