- Jul 30, 2006
Not an expert with flint and steel, howsowever...
Hardness of minerals is measured on the Mohs scale.
Flint has a Mohs hardness of 7.
According to efunda, an engineering data site, the Mohs hardness of a knife blade is 5.5
http://www.efunda.com/units/hardness/convert_hardness.cfm?cat=Steel&HD=HM
So I think you will not have to worry about a blade that is too hard to spark with flint.
I think to throw a decent spark that can be used to start a fire using flint, the steel must be non-stainless. Helps if it is high carbon steel, too.
https://en.wikipedia.org/wiki/Fire_striker
Stainless steel is "stainless" because of an adherent oxide layer that prevents water and oxygen from reaching the metal. That barrier against oxygen getting to the metal is going inhibit the oxidation reaction that makes the spark.
You can get stainless steel the throw sparks, but they won't be the stronger sparks that you really want in order to light your tinder.
