can i swap blades on Strider SnG?
I would like a SnG CC or Gunner Grip. But i would also like to have the 154 steel. If i purchased both the CC and a Lego in 154 could i swap the blades around and have a CC with the 154 blade?
You can do anything you want. :-) But the lockup is custom fit to each one so changing them might alter your lockup. And it will also kill your warranty if you tried to send an altered one in for service.
Correct
I don't think I would attempt to go Lego to CC the lock side is just too different
I have some modified SnG's, but I like to keep the lock side and blade matched and only change the scale. Even then you take a chance, since so much is custom fit.
Trading or selling and buying the CC with the CPM 154 blade is your best bet.
There really isn't much difference between the CPM 154 and S30V/S35VN(from a use standpoint, I don't know metal composition), due to the way they heat treat. Differences seen are mostly in the owners mind not reality, but CPM154 is a good blade,
Best of luck, no matter what you decide
If you're fast there is a CC SnG on the Strider Facebook page for $300 right now in CPM 154.
