- Dec 3, 1999
Well... if it's that hard for you to figure out, I'd suggest you build one of those very simple machines and see how much you would charge for it.
Well... if it's that hard for you to figure out, I'd suggest you build one of those very simple machines and see how much you would charge for it.![]()
Pesky , when I first started making knives I had a Craftsman router and tried doing just what you are asking. I used a 5/8" carbide burr (not spiriel) and removed all guards, extended it full length and hand-held it.( 0-1 metal) It would remove metal if you moved at a slow pace but metal chips would fly everywhere including getting in everything you did not want them in and when I turned it off to check the results all the dogs had jumped ship and I was left with a piece of metal that had harded in places and had to be annealed . From personal experience my advice is to use a rock or angle grinder until you can get yourself a belt grinder. To answer your question , yes it will cut but way too noisy and dangerous . Just a personal observation.
Hey Welcome and enjoy yourself relax.
Look at the plans for the no weld grinder. A KMG isn't $2000 and it is a great machine. But, as Nick said, if you were to built a good grinder you would understand why they cost what they do.
Find a good 2hp electric motor with a speed control (step pulleys work)
find a good contact wheel (or a make a platen with 2 small wheels)
Drive wheel
idler wheel and tracking adjustment
pulleys and belts
assorted steel.
Then figure out how long it will take to fabricate and assemble a QUALITY simple machine.
I have a lifetime of metal skills, a welder, a lathe and a milling machine. access to some pieces of free metal and hardware. I have a KMG and I have built a semi copy. It isn't complicated but, it isn't cheap, easy or fast.
If you want to know how, people here will help you built a machine and find the parts as cheaply as possible. Heck even the guy who makes and sells KMG grinders told me how to set up the bearings when I modified a Grizzly wheel to have bearings. But, you should ask it nicely. If you do you will get all the help in the world.
By the way I have a some carbide rotary files and a milling machine also. It is way faster to profile with a bandsaw and a belt grinder.
Now Nathan the Machinist has a thread where he show how he machines a knife. But he uses something WAY more expensive than a $2000 grinder.
Your idea may work, but, not real well and not very safely. I have am 57 and have a lifetime of those kind of ideas. I learned even with the bad ideas. Important thing is don't get hurt, keep thinking and learning.
A fairly large massive brittle grinding (?) bit spinning at up to 25,000 RPM being engaged with steel makes for some hellatious stresses. I can envision the bit exploding and sending chunks into whatever or whoever is nearby. I have never seen a grinding bit for a router. Nothing larger than a dremmel at least. I'd move over to a sander or files before trying for the Darwin Awards.
Best of luck.
Also there is a ton of great information in the threads at the very top of the list we call em stickys. Take a look at those for all kinds of great information and to help you learn and you reading them will help you get the basics. Enjoy. I love making blades Jim
You might get Goddard's The $50 Knife Shop. There are plans for a belt grinder on the cheap. It's a good referemce fpr getting started without being out a fortune. I've used his belt grinder and it works well.
Gene
