This is the unit I purchased to run my 3 phase mill.
It shows the Nema 4 enclosure. Keeping the drive covered is absolutely a must, as stated above .
9528 - KBAC-29 Gray Inverter
- Part No: 9528
- Retail Price: $446.00
- Sale Price: $343.09
- Qty:
The KBDA-29 Adjustable Frequency Drive is a variable speed control housed in a rugged NEMA-4X /IP-65 washdown and watertight die-cast aluminum enclosure. It is designed to operate from 208/230 Volts, 50/60Hz, single or 3-phase AC input, and operates 208-230 Volt, 50/60Hz, 3-phase AC induction motors through 9.0 Amps RMS. The sine wave coded Pulse Width Modulated (PWM) output operates at a frequency of 16kHz which provides high motor torque, high efficiency and low noise.
Setting the drive to specific applications is accomplished using the Multi-Function Keypad. To facilitate programming, all similar functions are presented in common groups. For more advanced programming, PC based Drive-Link� software is available.
The 4-Digit LED Display provides readout of drive operating parameters and programming functions and displays Output Frequency, Motor RPM, Output Current, Output Voltage, Bus Voltage, Function Codes, and Values, Fault Codes and Custom Units. The LEDs provide indication of the drive�s status and operating mode (Hz, PGM, LCL/REM, STOP, FWD, REV, OL and JOG/REM).
Main features include adjustable RMS Current Limit with I2t Motor Overload Protection. Flux Vector Compensation with Static Auto-Tune and Boost provides high torque and excellent load regulation over a wide speed range. Power Start � delivers over 200% motor torque to ensure startup of high frictional loads. Programmable Injection Braking provides rapid motor stop. Electronic Inrush Current Limit (EICL�
eliminates harmful AC line inrush current, which allows the drive to be line switched. A Multi-Function Output Relay is provided, which can be used to turn on or off equipment or to signal a warning if the drive is put into various modes of operation. The drive is suitable for machine or variable torque (HVAC) applications.
