Breaking Headline News: Turtles declare landslide victory, JT refuses to concede and demands a recount
Are you sure about that...and nobody thought it was impossible!![]()
Are you sure about thatI just vote .................impossible
I am no expert but I believe it is from the speed in which the water cools the steel.Actually you're right about "Katana will develop positive sori when quenched in water and negative sori when quenched in oil"
I have seen this happened to almost every simple carbon not just tamahagane. From W2 to 1050. I still can't figured out why quenching in oil develop reverse sori tho..
That is a small part of it.
The negative sori is formed as the edge cools and contracts while the spine is still rubbery austenite.
Then, as the edge reaches the Ms at 400F it rapidly expands as it converts to martensite (martensite has a larger structure than austenite) at the same time the spine is contracting as it becomes pearlite. The spine becomes fairly rigid and the edge becomes very brittle as this happens. This makes the positive sori form. If there is too much stress caused by all this, it results in the dreaded PING as the edge tears itself apart.
When you quench in water the thin edge cools extremely quickly and pulls the edge in and the tip down. As the spine cools it pulls the spine in and the tip back up.
When you quench in oil, the same thing happens to the edge, but because of the slower quench speed of oil, it does not then cool the spine quick enough to pull the tip back up resulting in a negative sori.
some folks would dismiss this as part of the forged grain flow
Not sure if this is directed at me but .... the specifics of a process in which a piece of steel is rolled down to thickness can affect its properties - including how fast is cools in different directions (those directions being the rolling direction, the in-plane direction perpendicular to that, and the vertical direction). If we are looking at something here where this steel has some lower level of conductivity in the vertical direction (due to the way it was processed) (and it crosses a critical threshold in terms of being too slow), might that explain what JT is seeing. The paper I cite above indicates these properties can differ on the order of a factor of three between the different directions.....
- 00:13:44 Write up a brief summary and have it to me by the end of the day.
- 00:13:47 My pleasure.
- 00:13:48 Layman's terms. None of that inside, bullshit jargon that nobody understands.
- 00:13:52 Yes, sir.
- 00:13:57 Oh, Mr. Shirley...
Agreed - but I really did intend that as a question directed to Larrin (and I did qualify my statement to those interested in the technical stuffWhile we all love jargon, some can be said just as easily in layman's terms
