- Dec 29, 2003
I'm fairly meat-headed when it comes to sharpening, hence the Sharpamker sitting on my desk :~) And while I can get a decent edge on most of my knives, I really don't understand what I'm doing to effect the edge.
Simply, I'm removing metal to form a V, in which the bottom of the V forms a sharp edge. Does that sound about right? Where I'm confused is when I hear terms like primary & 2ndary bevel and how they relate to the working edge and more importantly a sharper knife.
I recently tried to reprofile a knife that wasn't sharp and didn't have the same angles as my sharpmaker. Using a 1" x 6" diamond hone, I leaned it against my sharpmaker's rod and used the same stroke as usual. I'd tried sharpening several times on the 30 deg side but was never able to get a decent shaving edge on the knife (D2). I later took Thom Brogan's advice and sharpened for a while on the 40 degree side using the diamond hone, then the sharpmaker rods and in the end I finished up with the 30 deg side.
Voilà! A shaving sharp edge. This happens to be the same advice offered the in the video so I clearly should have RTFM better than I did. I'm wondering if someone can explain how this 2ndary bevel comes into play and why it worked so well in my case above.
