- Jun 2, 2007
My question is, both of these blades are A2 and both were heat treated at the same exact time and yet one came out the usual grayish color with rainbow in it (TOP) and the other blade is half like that with the upper portion somewhat the color of the steel when it first went in. (BOTTOM BLADE)
Can someone explain what I did wrong with the stainless steel foil? Or how I wrapped the blade? Is it because the blade has been buffed before on top and the bottom one wasn't? Do you guys usually use some sort of combustible in the packet. How do i get it consistently gray with the rainbow tones on the blades? Obviously the pattern isn't gonna be the same. Just makes it a lot easier to buff off and doesn't leave a ghostly pattern on the blade even with a light buffing.
Thanks in advance!
Pohan
Thanks in advance!
Pohan
