- Apr 12, 2009
1-micron diamond paste is pretty popular as a universal stropping option. Being diamond, it still cuts any steel very efficiently - and at the relatively small grit size, it's not necessarily too aggressive for most any steel. Green compound, on the other hand, would struggle to refine high-wear steels very well, as it's not hard enough to handle the carbides in those steels. But for something like an Opinel, green would work well for that and for other knives in similar steels of carbon or low-alloy stainless (Opinel's XC90, 1095, CV, 420HC, etc.).Thank you so much, man, you are a wealth of information. Yeah, man, I was reading something like that, that you essentially have to give a Scandi a microbevel to sharpen it on the SM. I'm debating learning on a cheaper alum oxide stone, while maintaining on the sharpmaker, while deciding on a full sharpener.
Also, none of my knives are dull, maybe a couple of old Chinese ones. My PM2s (keep going back to this because it is my most varied platform in terms of steel and I like the pattern) are everywhere from absolutely 100%, to "Well, you can tell someone made some cuts with it, but it's still sharp and ready to take to work if you need", no dullness, no cracking, on any steel worth mentioning. So they are all presumably good to strop. I was thinking about ordering some 1 micron diamond paste. Would you say that is a good strop-all? I wonder if one strop will handle things like soft carbon steel without being too abrasive, and also the heavier steels. I haven't had much luck with my green compound so far.
Yes, I will be definitely wanting something for my high wear steels as soon as I know what I am doing with the SM
And am looking seriously at a Wicked Edge
My own preferences for stropping are heavily biased toward doing it very minimally, if it's done with any compound at all. I tend to favor the slicing aggression left in the edge exactly as it comes off the stone. So, for any stropping I do, I use it mainly just to clean up the burrs and their remnants, without reducing the toothy bite from the stone too much. This means I usually strop without compound. I reduce & thin the burrs as much as possible on the stone first, so that a simple strop of bare leather or denim will still be enough to clean up the edge.
