How To Can someone school me on bolt on fixed blade scales?
Not sure....been doing some YouTube searching. A lot of people use standoffs and whatever screw you want, but then you need to counter bore for the inside of the scale too..
Don't buy their CT'BORE bits, they Suck!!!!
I love the supply company, and buy from them Often. But that tool is bad
I wish I'd have known that before I ordered some gulso bolts and the counterbore a couple days ago. Lol
Learn to make your own and you can configure them exactly how you want. These are titanium. 5mm diameter, #6-32 thread, 90-degree angle and a T25 Torx drive.
I thought spending the $30 for a counterbore and pilot was bad, now I need a mill and a lathe. 😆
OP, I'm playing with screw on scales again as well, for my cerakote and parkerized blades.
To get around sanding the finish off of the tang, I've been making sure at least the profile of the scales are finished before I send the blade out for whatever finish. (I do this for stonewash and black oxide that I do in house as well).
When I'm ready to glue it together, I pin and clamp the scales on, then put turtle wax on the tang, blade and edges of the scales and let it dry, then I take it apart, carefully wipe the surfaces to be glued with acetone then denatured alcohol, let that dry and then glue everything together. The wax lets the epoxy that squeezes out peel right off.
Here's one I just finished up today, since the gulso bolts and counterbore showed up today.
I ended up having to add liners when I hadn't planned on using them but this knife is pretty thin with 1/16" steel and 1/8" scales. The female side of the bolts were just a hair too long to tighten the scales to the tang but adding vulcanized paper liners made it just about perfect. With thicker materials it wouldn't have been an issue at all.
The counterbore seems ok, aside from the set screw for the pilot wanting to come loose a couple of times.
Looks good👍
"I ended up having to add liners when I hadn't planned on using them but this knife is pretty thin with 1/16" steel and 1/8" scales. The female side of the bolts were just a hair too long to tighten the scales to the tang but adding vulcanized paper liners made it just about perfect. With thicker materials it wouldn't have been an issue at all."
Just a note - You can grind them shorter if needed.
