so i understand making damascus for the most part i got the borax method understood fairly well. but i want to can weld some steel up and avoid the borax mess. anyways i have some retangular tubing that i want to do this in. i was going to use som e stainless foil wrap on the inside of tubuing to keep the metals from sticking. what i need to know is like with the borax method do i need to set the wled on the press or in the no oxygen environment will the weld set itself. pretty sure i know the answer is that it will have to be pressed down while in the tubing to set the weld. cant wait this going to be my first attempt at some damascus.
