I go down to 800 grit and sometimes 9 micron. Then over to the buffer. I use the gray compound and get a basic mirror finish. I do not spend too much time using the gray compound as it is quite coarse, and can cause orange peel problems if too much time is spent at the buffer, and the problem is compounded if one uses too much pressure and not enough compound.
Then I change out the wheel for the green chrome rouge. Rake the wheel and then load on the rouge. Use lots of rouge and apply it often. Again too little rouge and too much pressure can cause the unwanted orange peel effect. At this point the mirror finish will look good, if there are any scratches on the blade, then go back to the grinder and start the whole refinishing process over again.
The final buff is with the white fine aluminum compound applied to a loose muslin wheel. This puts the high luster on the blade.
