- Sep 11, 2005
I have a Spyderco Native and can "flick" or opening it using an inertial opening. Actually the Native is easier then the Delica.
A frequent error people make in trying to do an inertial opening is "waved it ... trying to flick it open". That can work with knives that have blades with significant mass (Spyderco Endura) but with smaller knives like the Spyderco Delica or Native that type of motion will only server to give you a sore arm.
Here is the key in doing an inertial opening.
Hold the knife in your right hand. With the knife oriented so that the blade comes out of the handle away from your hand, holding the knife with your thumb on one side of the handle and four fingers on the other side gripping the knife just over the pocket clip. Hold the pivot pin between the thumb and index finger of the left hand and rotate the knife slowly around the pivot pin, raising the elbow up 90% or so and then back down again towards your side. That is the motion you need to apply to do an inertial opening versus flicking your arm out in a wave motion.
When you do the above motion quickly the blade is put in motion around the axis of the pivot pin. When you suddenly stop the handle the momentum of the blade is the force that overcomes the tension on the blade (pivot pin and in some cases the locking mechanism) and opens the knife. This is more difficult to do if the blade has less mass requiring a quicker rotation and stopage of the handle to overcome the tension on the blade.
With practice the raising of the elbow doesn't need to be so pronounced and you can do it with more wrist action then elbow.
