I am not grinding any bevels at all, only filing the plunge, drilling holes, and profile. I am plate quenching, do not need to normalize cause I am using flat ground stock for stock removal. I think my problem with the stainless was not getting the blade cooled evenly when going into cryo (dry ice). First try I had two big clocks of dry ice, sandwiched the blade between em. Had problems getting it situated and the blade sat on one side for a min. Second time I used rubbing alcohol and it froze solid before I could get it into what I thought was slush. Could not see this cause of the vapor, let it sit overnight apparently on one side.The blades were flat out of the plates and it was after cryo they came out warped. My next plan is to get pellets instead of a block, and pour in the alcohol while situating the blade at the same time so I know I will get the blade submerged, and everything should cool down evenly. Or it could also be me taking 30min to pry the stuck foil off both blades. Got that problem solved BTW...
When I set the hot steel on the plates I close the jaws as fast as I can so the blade does not sit on one side too long.
I cooked a piece of O-1 just to see if I could get a blade cooked and tempered without the warp, and produce a finished knife. I have to have SOMETHING to show for this massive electric bill from firing the kiln so many times this month.
