Perfect thanks!
Okay now to reiterate on the centering (isn't this fun)
....... with minor adjustments (seen in
bold).
Brought to you by the Stickies
Centering the Blade:
Here we go:
1. Open blade to 90 degrees and tighten pivot so that it is really tight.
Tight as possible....... but not arrgh let me use all of my muscles, to break/strip it tight
2. Close the blade and loosen the frame screws so they aren’t tight, but still holding the frame together.
Maybe 3/4 of a turn loose.
3. While the blade is still in the closed position, pull blade towards the side you want the blade to move.
This is the important part. Since it's off to the right (I'm guessing looking at straightforward with the blade closed??? So the presentation scale or in other words....... non locking side). Press the blade over to the frame lock side of the knife, until the blade is touching it. Then, take a folded up piece of printer paper (folded into to 3x3 size square, this way it's nice and wide) and slide/wedge it in place to keep the blade touching the frame lock side of the knife.
4.
Now it's no need to pull/hold the blade, because the folded up piece of paper is holding it in place (to the opposite side in which it was off-center). So now you can tighten the frame screws. Haha, would you look at that....... Mr. Rubi (I know you're laughing xxxfalcolnxxx) already incorporated what I said but I just moved it up a few lines. Great minds think alike I guess
----> (Note: Using a folded business card or the like wedged in between the liner and blade to Hold position works well).
5. Loosen the pivot and adjust it to the desired tension.
As you can see the centering guidelines via the Stickies were already adequate and thoroughly written....... but the minor adjustments (seen in
bold) I made were more for "emphasis" than anything else.
By the way, this procedure should take no longer than 5 minutes....... and shouldn't cause too many problems, I hope
. I say that because I know you've done it multiple times already, and when things don't go as planned....... it can be frustrating/tiring.
(P.S.) You'll know when you've done it correctly, because the blade will be favoring the "frame lock" side of the knife, instead of the non locking side (as seen your photo). This way when you get to the final step of loosening the pivot to the desired tension, the blade will become centered when complete.
