- Oct 22, 2012
This one is for the steel junkies and engineers among us!
So, after years of researching steels, it has become clear that carbides play a major role in the edge-retention and wear resistance of modern alloys, and even some legacy steels. I have also seen how the size of formed carbides supposedly determine the achievable fineness of the edge, which makes sense on the surface. I have also read all about the different carbide-formers employed in modern steels, as well as the use of Nitrogen to replace carbon, in which case nitrides form.
So after years of forumites name-dropping the likes of Vanadium, Chromium, Tungsten, Niobium, and sundry other carbides, I would like to know more about them in relation to one another, things such as:
Which is hardest?
What are the hardnesses of the common carbides, in HRc or otherwise? I've seen Tungsten carbide advertised as 71HRc, I don't know if that's accurate.
Which is largest?
Which is smallest?
I know Niobium has the greatest affinity to form carbides, what does this mean to an alloy employing Niobium?
How do Nitrides compare, (in hardness, size, technical difficulty to produce, etc.), to carbides, and do the same elements yield the same results?
I know carbides aren't everything, but after years of reading, I've never seen a genuine discussion of carbides beyond composition charts that tell us the relative potential of the number of different varieties, not their properties.
Which is hardest?
Which is largest?
Which is smallest?
