GregS
- May 6, 2008
Is HRC a logrhythmic scale? If it's linear then is there really much difference between 59 and 60?
I was thinking the same thing when I read that.
+1To be honest I prefer tool steels developed for cutting tools, like O1 or M2, sadly which is not
among the choice.
Plain carbon steels are not a bad choice of course as they get excellent edge very easily.
Rockwell hardness is performed with a conical penetrator and the depth of penetration determines hardness. Since the penetrator is conical, the further it goes in the greater the surface area of the penetrator in contact with the sample. So resistance to penetration increases the further you go. Therefore the scale would not be linear, but that doesn't necessarily make it logorithmic either. If you were to plot the rate of change in surface area of a cone as H increases, that should also translate to the hardness values (I haven't done that and don't intend to). The harder the sample, the more pronounced this effect would be, so there could be (and probably is) a significant difference between Rc 58-59 and Rc 60-61.
how does infi fit into this in terms of 'stainless-ness'?
