MicroAlign
- Feb 1, 2004
ichor said:That certainly is not the info I got from the Cliff Stamp test of the Recon Scout and Trailmaster that I read:
http://www.physics.mun.ca/~sstamp/knives/trailmaster_recon_scout.html
He does say that the edges can chip on hard surfaces, although this is definitely not the case with my own experience using my Trailmaster, Recon Scout and SRK. Here is a direct quote from Cliff Stamp, from the link above:
"The blades were also very strong through the full body and could take heavy side pulls while lodged halfway in an old stump. This was a similar amount of force which broken several blades from Ontario, and bent the TUSK, and a couple of khukuris from Gurkha house. The edge was also pounded directly into woods and subjected to direct heavy side loads. Both blades handled this with no problems. This was much more force that what caused both TUSKs to suffer gross failure and the Cold Steel blades handled it with no problems."
My own experience with numerous CS Carbon V knives is that it is a steel that is very, very strong....takes and holds a great edge....and will rust in a NY minute if you don't take care of it, tho' no worse than the other carbon steel knives that I've been using for 50 years. Since I take good care of my knives and don't care about a little staining, I find no real advantage to stainless unless one is a diver or some such. Bottom line is......my CS Carbon V knives are exceptionally tough and very hard to beat for the money. My two cents. YMMV.
The test I was refering to was the point strength test where that CS blade narrows. Any knife maker can produce a 5/16" blade and have a reasonable amount of toughness to it. The 5/16" thick blade was CS's solution to the toughness issue of their steel which from my experience with BOTH the Trailmaster and Recon Scout has been lots of edge chipping on harder medias such as chopping through a White Tail leg. Not to mention that I used to have a SRK, Recon Tanto, Masterhunter, bird and trout, and a Gurka Kukri(which snapped at the tang) in Carbon V. I do like my Trailguide in Carbon V. I also have a San Mai Trailmaster that I prefer with it's rolled edge over the Trailmaster. Also, CS's San Mai products are top notch in terms of quality manufacture unlike the Carbon V blades which have poor manufacturing quality in comparison.
