- Jun 2, 2009
what steel is best and why (maybe a story or picture)
In my humble opinion, there is no best steel. They all have uses for which they're suited, and other uses for which they're not. What do you want your steel to do?
well i prefer stainless because it will not stain and holds an edge longer
righton.Heh, here in the traditional forums that's almost sacrilege, stockmanlover.
Like dawsonbob said, neither is empirically better, except for some very limited uses. Stainless is pretty much assumed for a diving knife for instance. Generally I think you'd have a hard time finding many of us who have used both that will agree with the idea that stainless holds a better edge. Some of the fancy new super steels are excellent, don't get me wrong, but for a balance of sharpenability, and taking that truly scary sharp edge, some of the carbon steels are pretty hard to beat.
Personally I have a couple stainless knives around, in the toolbox, floating around in the truck, etc. For the most part the only real plus I see to the stainless is that well, it is stain resistant. So I can ignore and abuse them without worrying about it. Nothing wrong with the decent stainless, although in a reasonable price range there are alot more crappy stainless blades than carbon.
For most of my edc and specific use knives I prefer carbon. I like the patina that it develops for one, it tells a story. I also find that while you may need to touch it up a bit more than the newest super steels, it holds an outstanding edge and is generally alot easier to resharpen. Now resharpening might be a pain to some folks, and if it was constant due to lousy steel I wouldn't want to deal with it either. But sharpening is a knife fondling retreat for me, and isn't needed too terribly often anyway unless I've been working a given knife really hard. So generally carbon.
YMMV
Syn
What he said.
Every alloy has a combination of properties. And no alloy has optimal properties for every use. Define how you expect to use the blade, then you can figure out what combination of properties you need the steel to have. Then you can identify which steel has that combination of properties.
