By the way, knarfeng, I tracked down a Vorpal blade for you. They're only made by Charles Dodgson somewhere in the Tulgey woods. Sorry, I don't have a URL or a price.
 Tulgey Woods is too far from IB to do me any good.
			In terms of slipjoints I feel that there are a disproportionate amount of good carbons vs good stainless, and I think that the lack of high end steels in commonly available knives may sway this thread.  In general I like the carbon choices better than the stainless (mostly Case, SAK's), but if given a choice between 1095 and CPM154 in the same knife then I would choose the CPM as I like it more based on my day to day uses- it fits me better and I feel that the edge is held longer, even if it does take me longer to sharpen- but diamonds work well on everything and I like sharpening.
My Opinion only.
I tend to agree with Mr. KRIS.  While I like both carbon and high end stainless blades, high end stainless will hold an edge longer than carbon steel.
As far as traditional pocket knife blades goes:
(which caveat I add because I don't usually know the hardness of the blades. Blades of most traditional style pocket knives have to be annealed [softened] at the base of the blade to allow them to be bent so they fit.  A flat area is required for the hardness measurement, so there is no flat area on most pocket knife blades that is at full hardness.  Testing the edge retention of an alloy without knowing the hardness means you only know part of the answer, since, the harder the alloy, the better the edge retention.)
Buck 420HC at 59HRC will usually outperform any of the carbon steels I have tried.  But it is probably the closest stainless to carbon as far as edge retention.
AUS8 blades will hold an edge much better than the 1095 and CV knives I have tried.
440C is better than AUS8 for edge retention
154CM holds an edge better than 440C.
It is difficult to find well-made affordable traditional knives in high end stainless.
Canal Street has made some trappers in 14-4 CrMo, the Latrobe equivalent of 154CM.  I have one and it performs about as well as 154CM.  Canal Street has some new knives out in 440C.  I've not seen any on the street (internet stores), so I don't know what street price will be.
Queen does provide knives with D2 blades.  The Queen D2 holds an edge on the order of 154CM.  (haven't done a direct comparison.)  Whether D2 is a stainless alloy or not is up for question. Not really stainless and not really carbon.  I only have one Queen.  I may have to get more.  But then I want more of everything.
