- Jan 17, 2008
Hey all. So as many of you know I have been playing with early and medieval knives. Specifically with welded wrought iron and steel construction. If you're curious I've got a couple of completed WIP threads on this forum.
Recently I've been watching a lot of Clickspring videos on youtube (mostly because I find machining videos to be relaxing
) He's done several videos where he has case hardened (carburized) mild steel to make files and drill bits in much the same way as Theophilus describes in "On Divers Arts." It got me thinking... Is there any reason I couldn't do the same thing to a wrought iron blade? Forge the blade to shape, grind it to maybe 85% or 90%, carburize it (pack with a mix of charcoal, flour, and salt and encase completely in a clay vessel, heat and hold at critical temp for a time) then heat treat and finish as I normally would.
I realize it likely wouldn't give the same performance as a modern blade. And that there would likely be fairly uneven carbon absorption due to the lack of homogeneity in the iron. My reasoning here is if they used this technique to make files (and we know they did), why not blades? Or am I missing something?
