I think I should make it clear that I think Gaston and his points are not only unfounded, but also laughably incorrect. I've seen first hand how blood great super steels are. My Cru-wear Manix and K390 Urban have shown alone that there are steels that just make normal steels like even D2 look like garbage, which in their own right are not bad steels at all. I did some very unscientific testing with some cardboard cutting, and despite cutting around 50% more than S35VN, my Cru-wear Manix was just had the slightest diminish to edge sharpness.
Oh really? You've seen it right...
I'll agree to that, what I'm disputing is this notion that seems to have flared up that there is no benefit at all to a higher end steel.
There is a benefit to higher end steels: Well treated 440B/C, Japanese treated Aus-6/8, and to lesser extent, D-2, are high end steels. S30V, CPM 154 and CPM 3V are low end steels.
I don't know about the others, but call me skeptical. Healthily so.
I think its clear enough that a higher end steel can be pushed farther as far as geometry goes. .
If "farther" means thinner, that is emphatically true. The problem is the "higher end steels" are not the ones you think they are... Also, thinner geometry can boost edge holding performance, so if you assume the wrong steel is "better", based on novelty, and give it a thinner edge geometry on that basis, then you are boosting the inferior steel at the expense of the better steel.
What is great about checking for micro-folding, after some light chopping, is that it is an entirely objective binary result: Either the apex grabs the nail material on one side, or it doesn't. There is little in between, except for the extent and continuity of the grabbing.
"Normal" paper-cutting sharpness tests by comparison are largely meaningless: Paper tells you little about the apex condition (except immediately after sharpening, de-burring and cleaning) and neither does it tell you much about the apex stability: An edge that degrades less, but to a rougher apex, will find the apex roughness more clogged with tiny particles, and so this clogged "lesser" apex will tear paper, even though it is both sharper and not leaning to one side like the "superior" CPM cutting edge is...
This probably explains why people are convinced they see large edge retention benefits with CPM steels...
I don't even see much in the way of careful edge-cleaning/wiping between "paper tests" on most videos, nor did I hear of it in any posts...: No verification of apex clogging. Pretty much says it all...
Gaston
