Cardboard Massacre!!!!
Jeff - I'll try a diamond hone on the Military some time, but not now. You wouldn't believe it, but my fine diamond hone gave out last night. That's the last time I buy a Lansky diamond hone. It bit the dust in no time!!! Maybe I'll order up one of those fancy DMTs. :D
A simple steel, huh? I like simple. :)
Originally posted by Buzzbait
So what custom makers do convex edges? Are there any custom folder guys who do convex edges? As you can tell, I'm really psyched about this. The thought of not having to sharpen is toooooo coooool. Call me a stropping fool!!!
Buzz - if you send your Sebenza back to CRK for resharpening, they will put the convex edge back on to your knife :)
Matthew
Buzzbait, if you like Talonite, get a Tom Mayo TnT. It has a super strong frame lock just like your Sebenza, Titanium handles(which don't scratch near as easily as the sebenzas), and a convex edge. He also just switched from Talonite to Stellite 6k, which should perform with even better results than Talonite!
Just my 0.02
Jeff
The BM735 does have a thick blade! The material (carboard in this case)just cannot get out of the way once cut and drags on the sides. My BM940 does a better job in cardboard.
Buzzbait :
[high performance of the Marbles]
Is it the 52100 carbon steel
No, the steel won't influence the cutting ability significantly except in except in extreme cases such as very low edge bevels (~6-8 degrees), or really high polishes (0.5 micron). The former case is much greater than the latter. I have yet to see any material that retains a high level of aggression at a 0.5 micron finish. While D2 will be more slightly aggressive than 52100 if both are at 0.5 micron, the D2 at 0.5 micron will be completely outclassed by 52100 at a 600 DMT finish (or 1095 for that matter).
or is it this crazily easy to maintain convex grind.
No, not directly. From what I have seen, Marbles has the primary grind directly forming the edge, puukko style, except they use a convex primary as opposed to a flat one. It is not the fact that the edge is convex that is gives the performace and ease of sharpening, but the fact that it is acute. You will find praises sung of full flat grinds (puukko style) in the HI forum, and they cut very well and sharpen easily, stropping just as you experienced with the Marbles. In regards to the cutting ability of flat vs convex in general (edge as well as primary grinds), it will be dominated by the cross section. If you put a lower flat grind on the edge it would for example readily outcut the convex one.
In regards to the low performance of the Military, when Spyderco switched to using ~55 RC 440V they may have thickened the edges. If this was the case then this would cause the blade to do poorly on cardboard. While primary grinds are important to cutting ability, they are an order behind the edge grinds in the magnitude of the influence they case. A fat sabre ground blade with an acute edge (puukko), will easily out cut a flat ground blade with a thick and obtuse edge (except in some really odd cases). For example after a number of people commented that the new SERE folder outcut the military (sabre vs full flat primary), someone measured the edges on both that they had and found that the edge on the SERE was much thinner. If you want to raise the performance of the Military then thin the edge out. You should be able to file it if it is ~55 RC.
In regards to heat treating, Bos has stated that Buck gets the highest quality heat treatment. Heat treating is a science, it is not some magical procedure which is effected by Bos being in the room. Bos can instruct someone to do heat treating to the same level that he can unless he is an incompetent instructor, which is a fairly harsh claim (or Buck hires imcompetent people besides Bos, which is also fairly harsh). Why would Buck tolerate their blades being inferior to the ones that Bos handles himself. The only reason that Buck's would be inferior is if Buck directed Bos to use a cheaper and inferior method so that they could cut costs; shorter temp times, no multiple tempers, no sub zero, quick and dirty soaks, sloppy quenches, overfilled ovens, etc. . However considering the way Buck treats performance in general this doesn't seem likely. I would however be interested in any actual facts otherwise.
Buzz, nice job on the cardboard cutting.
-Cliff
Hi Buzzbait. I bought the DMT set over the Lansky Diamond set (about the same price when new) because the DMT hones were supposed to last longer (seems to be true)....but BE ADVISED...the DMT aligner-clamp only fits up-to a 3/16" thick blade (and barely at that)...save your lansky guide-clamp for anything over that.
Cliff – It’s actually taken me a couple of days to digest what you wrote, and assimilate the facts into other things I believe to be true. If you could stand answering a few questions while I try to work this all out…
1. You stated that the choice of steel has a very minimal impact on the actually cutting efficiency of the blade, except when the grind is very thin or very highly polished. Can I assume that your words were directly related to the matter at hand, cardboard cutting? And that other cutting tasks such as chopping or piercing beer cans would be a totally different issue? I’m trying to sort out what extreme conditions require a more extreme steel.
2. On this same note, the choice of steel would not be noticed until a number of cuts have been made? Prolonged use is where the hardness, edge retention, and abrasion resistance start to shine through?
3. As for convex and puukko style grinds, I’m not seeing the downside. Comparatively few knives are made with these types of grinds. Why is the knife world dominated by your average hollow grind and two distinct edge bevels? Is it that hard to convex or puukko grind most steels? Or is it just too hard to polish most steels?
Thanks again for the cold hard facts.
Thought of this thread last night @ 2am.
I had to cut up the box that our new 32" TV came in...
This is hardcore, heavy duty corrugated cardboard...the box weighs a pound or two...
I had my Dozier K-9 on me and boy was I surprized!
Push cuts!
I thought I'd have to angle the blade (point towards the floor) to get the board to ride the length of the little blade. Nope! With the blade parallel to the floor, I just pushed down!
Simply amazing (to me at least ;))
One trick I have learned working in an art studio is to cut on an angle (45*) thru the board, instead of the blade being perpendicular to the board. This way the board separates, instead of wedging the blade in :)
"Dozier Sharp"
Gotta love it!
For a great convex cardboard cutter try an Opinell . thin and shallow convex grind works unbeleivable.
BTT
Would hate to see this thread die prematurely.
I agree. This thread has been turning into the holy grail of knife understanding..... At least for me. I've learned more in this thread than I have the whole last six months.
My guess is. The reason you don't see alot of full, edge to spine, flat or convex grinds is it removes alot of steel. Therefore it taks more time and work. Performance seems to have nothing to do with why there are not many made that way.
That sounds logical to me, DB, though I may be easy to fool. :D Can anyone refute this?
Looking at it from the flip side, does the hollow ground blade offer any advantages over the flat or convex ground blade from the user's standpoint (in a utility knife, or hunting knife, for that matter)??
Well, 6K has more carbon, so it should hold an edge slightly longer than Talonite. People I know and trust that have experience with both of these materials also say that 6K holds it's razor edge slightly longer than Talonite, but it is quite hard to tell the difference. Other than carbon content, these two materials are relatively the same.
Jeff
Phlatinum
Yes it sure does. A hollow grind that is done right is a great cutter. The big plus with them is they can be sharpened without haveing to remove alot of steel for a very long time. As they are thin farther up the side of the blade unlike flat or convex whitch get thicker the farther up the blade.
A hollow grind that is done right is a great cutter. The big plus with them is they can be sharpened without haveing to remove alot of steel for a very long time. As they are thin farther up the side of the blade unlike flat or convex whitch get thicker the farther up the blade. [/B]
That would seem to be a very valid point. I guess you are saying that the flat and convex blades are more difficult and/or more time consuming to keep properly sharpened pretty much from the start. (Correct me if I assume too much here.)
Now, what does that say about the guy who demands a convex or flat ground blade? Is he just willing to put up with a harder-to-maintain blade because it's cutting performance is so much greater, or is he just fooling himself? Or is there another reason for his preference? (Doesn't the hollow ground blade require more frequent sharpening than a convex ground blade due to it's weaker edge?) Do the flat and convex blades require more sharpening skill than the average guy possesses or is likely to develop? I'm asking these questions to try to determine which type of blade I would be most content with in the long run.
Another possible consideration .... Would it be accurate to say that the flat/convex ground blade has a longer total life expectancy than an otherwise similar hollow ground blade, or vice versa? Or is it a wash?
Here’s my take on things. From what Cliff said, it sounds like the thickness of the blade is a big deal, with it becoming less and less of an issue as you move away from the working edge. Seeing as the Marbles must have a nice thin edge, and that it is a convex grind, I don’t think that the hollow grind has much of an advantage in cutting efficiency. This, of course, is assuming that the designer is talented enough to build a blade with a good geometry.
The big issue, at least for me, is whether to bevel a blade’s edge or let the edge run smooth to the tip of the knife. Let’s use a flat ground blade as an example. The Spyderco Military has a flat grind and beveled edge, while a puukko style knife sounds like it has a flat grind with no bevel.
My experience is exactly the opposite of what db described. I have had to sharpen my beveled edges to keep them sharp. Each sharpening has removed a bit of steel. I only had to strop my Marbles, which effectively removed no steel. The stropping just polished the edge, which was enough to make the non-beveled edge razor sharp. I’d prefer to strop than sharpen any day.
I’m guessing that the big factor is the type of steel. If a non-beveled edge chips out on you… You’re screwed. I don’t want to even think about trying to remove a chip from my Marbles. I’m not even close to that talented with a bench stone. The average Joe can easily remove a chip from a beveled edge with a Lansky type setup. I’ll make a big old leap and gather that today’s stainless steels of choice may chip too easily for a non-beveled edge. Maybe beveled edges are only practical for basic carbon steels and talonite.
Buzzbait :
There is really only one way in which steels can influence a difference in the cutting ability and this is by effecting how "sharp" they can get. In regards to slicing, while it is true for example that D2 at a very high polish will out slice 52100 at a high polish because the grain structure of D2 is much more coarse than 52100 (30-50 microns as compared to 0.5-1 micron), both slice very poorly at a high finish, so it is a matter of one being "less bad" than the other. If you sharpen both at a decently coarse finish like 600 grit DMT so that both slice well, you will see no difference in slicing ability between the two as the level of micro-teeth left by the DMT abrasive is much larger than the grain of either of the steels so the grain size is totally masked. The opposite is true for push cuts. At a high polish, 52100 will take a finer finish than D2 because of its smaller grain size, however in order to actually detect this you have to sharpen at an angle which forces the more coarse grain steel to break apart at the edge. Typically from what I have seen this means you must go below ~10 degrees per side, which is far below most modern cutlery.
Yes, the steel type can effect edge retention and thus reduce the cutting ability, however the initial performance will be identical, regardless of the steel, except for the cases given in the above. To clarify the above, in order to actually see the difference I mentioned, I had to do some really controlled cutting where I could see performance changes on the order of less than 5% . It is very difficult to notice these things by "feel", unless you spend a lot of time doing it. This again is why I don't thing steel type should be linked to cutting ability as even when you can see differences, they are very small. Steel type should be chosen for reasons of edge retention, overall durability, corrosion resistance etc. . Which brings up another point. In the above I assumed that the geometry was the same for the D2 and 52100 blade, in general this should not be true as 52100 is much tougher and thus should be able to make a higher performance cutting blade, except on light work where even the durability of D2 will not be exceeded.
3. As for convex and puukko style grinds, I?m not seeing the downside. Comparatively few knives are made with these types of grinds. Why is the knife world dominated by your average hollow grind and two distinct edge bevels? Is it that hard to convex or puukko grind most steels? Or is it just too hard to polish most steels?
The most common using knives (blades) have full grinds, such as puukkos, parangs, khukuris, axes etc. . They have only one drawback and this is that when you are sharpening you must work the entire bevel. However they have the advantage that if you do so, the cutting ability is constant as the geometry of the edge stays the same. This doesn't happen with knives with secondary bevels because each time you sharpen them the cutting ability goes down as the edge thickens. This change happens faster for convex than flat than hollow primary grinds with secondary edge bevels.
phlatinum :
There are two ways to hollow grind a blade. The following shows flat, traditional hollow, convex and hollow relief :
http://www.physics.mun.ca/~sstamp/images/grinds.xfig.gif
The problem with the traditional hollow is that the curvature near the top is quite extreme and the blade binds badly on deep cuts. The primary advantage over a flat grind is that since you have more metal removed from the upper part of the blade you can go with a thicker edge and have the same level of cutting ability and thus have a more durable edge under light impacts. However the downside is that if the durability of the edge is exceeded you can blow a piece out of the primary grind and thus basically write off the knife. The other advantage is as db mentioned, this grind is the more stable than flat or convex (with secondary edge bevels) under repeated sharpenings.
The hollow relief grind (found on axes, khukuris, etc.) is basically a hollow grind on top of a flat or convex primary grind. Unlike the traditional hollow, the hollow relief enters and exits the blade at a very similar angle, and thus it has has no problem with binding on deep cuts and in fact will greatly increase deep penetration. It also has the huge benefit of directly increasing the ease of sharpening. You still sharpen the entire bevel, just that now the middle has been removed and thus there is far less metal to grind. If you thought stropping a full grind was easy, try a hollow relief.
The downside to both types of hollow grinds is of course the extreme fragility in case of impacts, and the much lower strength than flat or convex grinds, neither are of any important for small cutting knives.
Posted by phlatinum :
Flat or convex full ground blades with no secondary edge bevels will last much longer than hollow ground blades with secondary edge bevels. What tends to happen with full ground blades (no secondary edge bevels) is that as they are thinned with repeated sharpenings, they get used for lighter work. For example a wood chopping parang that is flat ground and starts out at 1/4" thick and 2" wide may after many years be cut down so it is only 1/8" thick and 1" wide, it now is devoted to a light grass/brush cutter. On the flip side, if it had a secondary edge bevel, after the same amount of sharpening, it would still be 1/4" across the spine however the edge would be so thick that it would have long past the point of being useful as a cutting tool and would be used instead as a root / sod hacker.
Buzzbait :
.... the thickness of the blade is a big deal, with it becoming less and less of an issue as you move away from the working edge.
Exactly, as when cutting materials the force they exert on the blade (binding), falls away very rapidly as you move away from the edge.
The big issue, at least for me, is whether to bevel a blade?s edge or let the edge run smooth to the tip of the knife.
There are a few reasons for the introduction of secondary bevels. First off knives are not really cutting tools anymore. As an example look at any well known "tactical" knife, it will easily be out cut by one of the larger Swiss Army knives. When you want to use a knife for digging in the dirt, chopping bone, coming into contact with hardened metal etc., you have to alter the profile away from one of optimal cutting ability. To make matters worse, the cutlery industry is flooded with steels that are really unsuitable for the knives they are being used on, because of their extremely brittle nature (ATS-34 as compared to say L6), and thus the geometry of the edge has to be made even more obtuse. Third, the introduction of gadgets like the Sharpmaker, which are designed for secondary bevels. Which came first is not trivial, but the flood of such products certainly makes using full grinds not that practical if you are a maker. Lastly, fully ground blades look horrible after they are sharpened as you are abrading the entire bevel, this is not a practical geometry for the huge part of the market which is influenced by the look of the primary grind (coatings, various decorative finishes).
However, if you just want to use your knife as a pure cutting tool, and you don't care that the bevel gets scratched up none of the above applies to you and thus go with a full grind, optimally with a hollow relief. Edges can be ground right down to 10 degrees for about any steel and ~6-8 degrees for the finer grained ones. These edges will not be damaged when slicing wood, rope, cardboard, etc.. For wood chopping you don't even have to go that much more obtuse assuming you are working on clear soft woods, with good technique. If you are chopping knots you want a thicker bevel, ~12-14 degrees, more if the technique is poor, or the wood very hard. The reason that people recommend angles like ~25+ degrees per side for simple wood chopping is simply becuase the steels being used in the blades are not suitable and thus you are having to compensate for a lack of toughness. Bone chopping requires a more obtuse edge again, but this is now starting to now really be a cutting knife anymore.
There are two very basic techniques for sharpening full grinds :
The first is to simply hone the full bevel producing an angle that is constant form spine to edge. This is how puukkos are sharpened, usually at 8-10 degrees. The second method is for blades with primary grinds that are much more acute. If your primary grind is flat at 2-4 degrees, the edge formed by this angle will be rather weak. Thus as you are stropping, you roll the blade upwards just on the last of the stroke. This creates a very minute secondary edge bevel, left usually at just a few degrees above the primary. This increases the strength greatly and only loses just a little bit of cutting ability. Note each time you sharpen you are still working the whole bevel, you can do touch ups on the micro-bevel to save yourself some time, which is common practice. Convex bevels are handled in the same manner, you just arc the hone over the bevel if you are using a stone, or use a slack piece of sandpaper (or one on a really soft backing), if you are using a stropping motion.
-Cliff
