Carter / Gl Drew / Mason / Stiff Horn Sneak
busterbones
Feedback: +223 / =0 / -0
Josh Mason Japanese Wharnie Necker - w/Kydex $110 shipped
Steel - O1 tool steel.
HT to recommended specs in my digitally controlled Evenheat oven
OAL - 6 1/8
Blade length - 3 1/8
Razor sharp chisel grind. Scotchbrite machine satin finish. Unsharpened swedge on top.
Carter Muteki Series Pipsqueak
STEEL: White Steel laminated with Stainless Steel
FINISH: Forge Finish, unpolished $
with joufuu sheath and a black index sheath.
Stiff Horn Sneak $125 shipped new!
AEB-L 3.25" blade, OAL 7.25" hollow ground, Rockwell 62c with liquid nitrogen cryogenic treatment.
Hollow ground on a 10" wheel.Finished to a 400 grit then given a non reflective glass bead blasted finish.
The scales are coarse texture black G10 mounted with 6-32 bolts into custom made brass threaded rod.
Knife weighs in at 3.7oz
GL DREW whittling set
$115 shipped
