- Jan 26, 2002
I had to try it, and it worked out pretty well.
I checkered the wide ring of a horn handled 15" AK.
What I did:
cut strip of heavy paper to match handle area width and circumgerence.
laid out pattern on paper. Remember width of cuts!
Used diamonds about with about 1/4" sides. Two across on the handle area. 11 diagonal lines each way.
transfer pattern to handle (pencil), lightly scribe with exacto knife. Can sand off at this point if you change your mind!
Used x-acto chisel blade to make shallow v-notch following pattern. press straight,down, don't pry, or small pressure flakes like knapping glass can result.
Deepen and straighten cuts with hand-held hacksaw blade. Deepen using knive again. Repeat until deep as desired.
Hacksaw blade goes kinda slow, but won't cause real damage on a skipout.
Polish cuts with folded sandpaper, I finished by wet sanding with Alberto V05 hairdressing (petrolatum and lanolin). Light color of cuts won't go away without some type of dressing or proper rouge buffing which I'm not equipped to do.
Hand buffed with brown paper and it's nearly as shiny as original condition. Rouge and some elbow grease would probably take it the rest of the way.
Took a couple of hours and the looks and grip are improved.
Good luck, just go slow. I would make sure the handle has been well-treated with some kind of dressing and had a chance to stabilize before carving.
What I did:
