Thanks for your thoughts on it David. Getting into the behavior of some of these steels usually goes way above my head. The discussions can become so dynamic, taking so many factors and variables into account.
My way to judge a steel is to buy a knife, sharpen and use it
The reason I brought up the heat treat topic with this steel is I wondered how much of the problems were attributed to this. In Carl's place I mentioned putting a deer out of it's misery by placing my knife's blade through its skull. The blade was 154cm and there was NO chiping and the edge was still sharp.
Thanks for helping me understand it better
Exactly. This is why I 'obsess' over this stuff, and sharpening in particular. Early on, I'd read a lot about how certain steels are supposed to behave, but never really 'understood' what that meant. But, over time, after re-bevelling so many knives from an accumulation of probably 300+ knives in many different steels, certain patterns & similarities start to show themselves between steels of similar chemistry, and the pieces of the 'jigsaw puzzle' start to just fall into place. That's where it really starts getting fun, when you start looking at the published chemistry and can somewhat predict what to expect when you go to sharpen it up, for the first time. That's also handy for figuring out what sharpening tools might work better than others (diamond, SiC, AlOx, etc.), for a given steel type. I still can't claim definitively that I actually know this stuff, in the academic sense, but I do feel like I've gotten a much better feel for it, than I had just a few years ago. And I'm still learning...
Edit:
"ETA, I also always wondered how much of the 'chipping' was actually people not understanding how to remove a burr and the burr being damaged.?
On the other hand, s30v can really feel gummy when grinding and sharpening and I had it chip on cardboard when my Damascus Case/Bose would not.
It really gets puzzling to me sometimes. "
I missed this part of your earlier post, when replying.
I do believe (strongly) that burrs & wire edges account for a huge portion of reported 'dull' edges, whether they're reported as 'chipped', 'dinged', 'dented' or whatever. That's sort of an extension of the 'plastic deformation' issues I mentioned; the edge will bend, fold, dent or otherwise 'deform' like plastic, when subjected to stress or impacts or whatever. I went for years (& years) not understanding the effect or even the concept of a 'wire edge' on a blade, and so I have no doubt others go through it as well. A whole lot of my 'dull edge' issues went away permanently, when I finally figured out what was really wrong, and made an effort to clean the burrs & wires up.
S30V is still sort of an 'odd duck' for me. Lots of commentary in the Maint forum, about how it is known to have relatively large carbides which will 'tear out' of the surrounding steel matrix, and therefore leave voids in the edge. Whether this is actually 'chipping' or not, I don't know. But the end result is an edge which appears to be chipped (pieces of material missing). That's another steel which really seems to behave differently, depending on heat treat. I could see how it might seem 'gummy', as you describe, when grinding, at lower RC. As for the damascus Case/Bose, I don't know if it has the same abundance of (vanadium) carbides as S30V, but I'm betting it doesn't (S30V's vanadium content is HUGE). That might account for why it didn't seem to chip in the same way. Obviously lots of other variables too (chemistry & heat treat). Damascus steels often have more nickel content, which is what accounts for the 'bright' portions in the grain pattern of the damascus. Nickel is known to increase toughness and ductility (opposite of brittleness), so that might also play a part.
